The Tuul Crib 7,336 #1 Posted July 31, 2020 A friend of mine sent me a picture of these cans don't know if it's a real thing or not. 2 9 Share this post Link to post Share on other sites
Pullstart 62,798 #2 Posted July 31, 2020 Never seen it, but I feel like I might need it! That should go right along with a Poulan chainsaw. You keep poulan and poulan! 1 8 Share this post Link to post Share on other sites
Ed Kennell 38,024 #3 Posted July 31, 2020 25% ether.......It starts up or burns up. 5 Share this post Link to post Share on other sites
Tractorhead 9,064 #4 Posted July 31, 2020 Never used that Starterspray‘s on any of my Engines, just find the Naming funny 😄 On Chainsaw i only use Aspen Fuel since years. I like that Fuel, because it can be stored up to 3 Years without any problems. The combustion chamber is nearly as clean as on first day. No Smoke no Smell and it fires right up after second pull at least, no matter how long the Chainsaw was parked between the uses. i stay away of any of the Startspray‘s, especial on Diesel Engines in colder Winters. if an engine would not start - something is wrong - fix it - that simple. Pre warmed Air is the best Startersolution for a cold Diesel in Winter. Seen few Diesel and even other Engines over the years they be destroyed, while driver uses excessive Starter Spray on worse starting Engines. Sterterspray’s are definitely not a solution i would go or advice. 3 Share this post Link to post Share on other sites
DougC 2,641 #5 Posted July 31, 2020 In 1982 I exploded a muffler on a Chevy Cavalier when none of them would start when the temps were below 20F. The Service Manager took the can of either away from me and told me to get a broom and sweep up all the muffler fiberglass after it quit falling from the ceiling. Talk about a big KABOOM!!!!!!!!!!!!!!!!!! 5 Share this post Link to post Share on other sites
Stormin 9,981 #6 Posted July 31, 2020 I don't like easy start spray cans either. Once you start using them on an engine, you keep having too. Result? Knackered engine. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,336 #7 Posted July 31, 2020 I don't use them as well but someone sent this picture to me I thought it was kind of funny. They definitely will score up the cylinder walls.! 1 Share this post Link to post Share on other sites
cafoose 3,354 #8 Posted August 1, 2020 They do sell it in Australia! 1 Share this post Link to post Share on other sites
