71_Bronco 1,072 #1 Posted July 30, 2020 (edited) Have a '62 Lawn Ranger that I was going to put new wheels / tires on. The current stock tires are 4.80-8's in the back. This is the model with the tool-box and fenders like an RJ has. I was looking at tire and wheel options, and with the inspiration of the later, seat-pan-style Lawn Rangers, started looking at fatter tires. I can get a set of 8" diameter, 7" wide wheels, and throw on a pair of 16x7.50-8 tires. Would maintain the same OD, but would be almost double wide. Can't seem to find anybody who has done this before, and I'm not even sure this is a good idea. I had thought of building some kind of dual-wheel set-up, but the wider wheels / tires would be much easier / readily available. Thoughts? Edited July 30, 2020 by 71_Bronco Share this post Link to post Share on other sites
Pullstart 63,203 #2 Posted July 30, 2020 Are they hubs like other Wheelhorses, or keyed hubs? I’d imagine if that transmission is as tough as other 3 and 8 speeds, there’s no reason not to go bigger, so long as you get the proper offset to clear the fenders Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,136 #3 Posted July 30, 2020 Does this enter the picture? Model 5048 transmission could be upgraded to a model 5053 with kit # 7168 Garry Share this post Link to post Share on other sites
71_Bronco 1,072 #4 Posted July 30, 2020 I think I have the 5025 in the Ranger now (stock). The wheels are keyed dirrectly to the 1" shafts, no hubs. I do have a well-working 5053 that I pulled out of my Commando 8 (to swap in an 8-speed). That one is pretty much the same, but has 5 x 4.5" hubs on it. I guess it wouldn't be any more different than the 23-10.50x12's I had on the 5053 previously 1 Share this post Link to post Share on other sites
Pullstart 63,203 #5 Posted July 30, 2020 4 hours ago, 71_Bronco said: I think I have the 5025 in the Ranger now (stock). The wheels are keyed dirrectly to the 1" shafts, no hubs. I do have a well-working 5053 that I pulled out of my Commando 8 (to swap in an 8-speed). That one is pretty much the same, but has 5 x 4.5" hubs on it. I guess it wouldn't be any more different than the 23-10.50x12's I had on the 5053 previously that 5053 would be my vote! Gearing must be different, whether input pulley or something inside the case? Share this post Link to post Share on other sites
71_Bronco 1,072 #6 Posted July 31, 2020 1 hour ago, pullstart said: that 5053 would be my vote! Gearing must be different, whether input pulley or something inside the case? From what I gather by our local WH transmission guru, I think the only difference is that the 5053 has the updated shift rails for better engagement / preventing 2 gears from engaging at once (flats on shift rails to prevent vacuum lock). Share this post Link to post Share on other sites
