tallen4392
c 81 deck
tallen4392
does anyone know if a 48 inch deck off a 141 will fit on a c 81  I am looking to buy the 141 with deck but want to put that 48 inch deck on my c 81 and sell it and keep the 141 hydro for pushing snow  thanks
gwest_ca
Yes it will fit but grossly under powered. The largest deck on the C-81 attachment list is 36".
Garry
Stepney
The 8hp will .. just barely pull a 42" at a slow speed. Forget the 48" but it will mount up.
You'd be best suited to keep it on the 14hp.
clueless
Back in the 70s and 80s my local WH dealer who was also a southeastern rep for WH sold 42" rd decks on 8hp tractors. He said down here a large majority of lawns are centipede grass that we cut at a 2" height. The rd does not need the extra power to throw the clipping out like the sd does. My first WH was a used 74 B-80 with a 42"rd deck that I bought from him in 1986, I cut my yard for 14 years with it, no problem. Now the 3" stuff could be a bit of a struggle especially if it was damp. Now as far as the 48" it will fit, will it cut :snooty:.
Edited by clueless
Goldnboy
The B80, C81, c85 will spin a 42"SD  easily  i would typically  mow in H1 or L3 gear.
Ed Kennell
I have a 48" SD on a C-120 and it cuts in short grass, but struggles in the long stuff.
I also have a 48" SD on a 417A  that is unstoppable.   And it sounds like it's happy when it gets on the governor.
A 48" on a 8HP ......not a good idea.
