biged77 113 #1 Posted July 28, 2020 I recently sent a Kohler 4705362 carburetor to Bill Miller for rebuild. My mistake, now I need a carb for my 310-8 M10. Looking at a Kohler #26 replacement carb from Isavetractors for $60. Don't want to go the Chinese route and Kohler carbs are out of sight. Any feedback on carbs from Isavetractors would be appreciated. He says they are made in the USA. Share this post Link to post Share on other sites
WHX?? 50,701 #2 Posted July 28, 2020 No knowledge of his carbs guy but I have pretty good luck with the China knock offs. After all this is a hobby for some of us so we have to cut corners to be able to buy more tractors. We do appreciate you wanting to stay American tho. 5 Share this post Link to post Share on other sites
oliver2-44 10,357 #3 Posted July 28, 2020 I bought 2 Chinese carbs, one for my C-160 and it was junk. Nothing changed no matter how you adjusted the needles. The one for a 8hp kohler worked fair. I now do my best to find used kohler carbs and rebuild them and bush the throttle when needed. 5 Share this post Link to post Share on other sites
Stepney 2,350 #4 Posted July 28, 2020 I've had dozens come to me for repair work after actual shops gave up.. 99% of the time they may or may not run semi OK but .. not well. The rest of the time it simply won't run at all. Funny Mr. Miller's name has come up so much recently.. If another member doesnt have one around, I'll check my horde, may have a rebuildable one I'd be willing to rebuild and bush, test out on an engine, and send your way if you were game. Done that a time or two in the antique sled world. 3 3 Share this post Link to post Share on other sites
ebinmaine 70,699 #5 Posted July 28, 2020 5 hours ago, oliver2-44 said: I bought 2 Chinese carbs, one for my C-160 and it was junk. Nothing changed no matter how you adjusted the needles. . I now do my best to find used kohler carbs and rebuild them and bush the throttle when needed. ^^^^^^ This is the experience I have had as well. Not familiar with isavetractors' carbs but I'll ALWAYS find a used Kohler carb and rebuild it. 2 Share this post Link to post Share on other sites
The Tuul Crib 7,338 #6 Posted July 28, 2020 I do remember reading threads of some members here using isavetractors carbs with no complaints. l myself have not used normans carbs but wouldnt hesitate. I would steer clear of the Chinese carbs. The inlet fittings are metric threads and the old ones wont fit the new one. 2 Share this post Link to post Share on other sites
peter lena 9,087 #7 Posted July 28, 2020 every time i read the same problem , i usually send the best carb experience i have had , https://isavetractors.com/?gclid=EAIaIQobChMIm7qBh-_v6gIVq9SzCh0gawLNEAAYASAAEgIjC_D_BwE , this is the best carb that i ever gotten from a net site. the carb was sealed in a plastic bag , was installed , and has never been touched for adjustment or running issues. my experience is that for the money , its so worth it , instant starting , no problems , no issues , worth a look , pete 3 Share this post Link to post Share on other sites
clueless 3,111 #8 Posted July 28, 2020 11 hours ago, biged77 said: I recently sent a Kohler 4705362 carburetor to Bill Miller for rebuild. My mistake, now I need a carb for my 310-8 M10. Looking at a Kohler #26 replacement carb from Isavetractors for $60. Don't want to go the Chinese route and Kohler carbs are out of sight. Any feedback on carbs from Isavetractors would be appreciated. He says they are made in the USA. I bought a #16 carb from Norm at IST a couple of years ago, worked fine. I think Norman is a straight up guy I would double check about the carbs being made in the USA . Hard to believe that their building replacement carbs that cheap, a few years ago DeWalt had a American flag on some of their small hand tool boxes and bags under it in small print it read assembled in the USA. 1 Share this post Link to post Share on other sites
oilwell1415 563 #9 Posted July 28, 2020 My experience with replacement carbs in general hasn't been good. Year before last the engine on our push mower started surging. I removed the carb, cleaned it, put it back together and it was fine all year. Last year it wouldn't work right at all. The needle and seat wouldn't seal, so it just dumped gas through the engine as fast as it could. Went to buy a needle and seat at the dealer and it was $75, but a whole new carb was only $30. Bought the carb. It worked great all last season. This season it has not run correctly all year. In the spring when it was cooler it was hard to start after 15 or so years of starting on the first pull and surged badly just like it did last year. And this one can't even be adjusted in any meaningful way. Thinking about taking the needle and seat of of the new carb and putting it in the old one. Does anyone make an adapter to put a Holley on a lawn mower engine? 1 Share this post Link to post Share on other sites
pfrederi 18,324 #10 Posted July 28, 2020 I save tractor carbs are not made in USA. i bought one for a K341 never could get it to run right. Have had mixed success/failure with much cheaper Chinese carbs. 4 1 Share this post Link to post Share on other sites
bottjernat1 2,190 #11 Posted July 28, 2020 Best way to do it is to buy online but pick the person or business that has the best feedback. I have bought many knock offs and had great success. But saying that isavetractors has a great reputation. I also believe they dial them in for you most of the time you can just slap the carb on and go. Isavetractors seem to be of a better quality. Even the chinese can make some good stuff. It depends on what you want to spend. 2 Share this post Link to post Share on other sites
squonk 42,516 #12 Posted July 28, 2020 I haven't run across a Kohler carb yet that couldn't be repaired with a bushing and carb kit. 2 Share this post Link to post Share on other sites
bottjernat1 2,190 #13 Posted July 28, 2020 16 minutes ago, squonk said: I haven't run across a Kohler carb yet that couldn't be repaired with a bushing and carb kit. I agree 99% of the time i rebuild them myself. could do it blind folded. LOL Share this post Link to post Share on other sites
Redneckdavis 308 #14 Posted July 28, 2020 Well. All this makes me glad I had guy throw in a box with 3 OE carbs to go with my k341. I was thinking faster would be $20 Chinese carb but looks like carb kit on and original is the best route Share this post Link to post Share on other sites
biged77 113 #15 Posted July 28, 2020 Thanks guys for the feedback on aftermarket carbs and clarifying that the Isavetractors carbs are not made in the USA. I have decided to go with used OEM carbs (Kohler, Walbro, Carter) and may have found one. For future reference, used OEM carbs would be a quick sell item here or on ebay I think. I didn't see any advertised. Share this post Link to post Share on other sites
ebinmaine 70,699 #16 Posted July 28, 2020 2 minutes ago, biged77 said: Thanks guys for the feedback on aftermarket carbs and clarifying that the Isavetractors carbs are not made in the USA. I have decided to go with used OEM carbs (Kohler, Walbro, Carter) and may have found one. For future reference, used OEM carbs would be a quick sell item here or on ebay I think. I didn't see any advertised. I've bought a couple from Lincoln at A to Z tractor in PA. That's one of our own vendors. Good guy. 2 Share this post Link to post Share on other sites
RandyLittrell 3,894 #17 Posted July 29, 2020 The positive thing about the china carbs is that it cut the price on used kohler carbs. The price got kinda stupid for awhile and I'm sure that was part of the reason they starting making the china carbs. I just have one and it is on my 1277 right now and running great, but I have a box a used carbs I need to rebuild some winter and then they will go back in rotation. Randy 1 Share this post Link to post Share on other sites
wrightorchid 261 #18 Posted July 29, 2020 I bought an isavetractors carb and had to modify mine a bit to make the air filter fit. The governor was too long, for the Magnum 12 that it was going on. The mounting bolt is much tighter, and requires a narrow wrench to attach. not the same casting as the original. It does not run any worse or better than before, but I think my motor is also due for a rebuild. Norman was very responsive on emails and support. The import carb pictures all look the same, so I would guess they are from the same factory and would doubt they are rebuildable due to parts support. 1 Share this post Link to post Share on other sites
