stoneman61 1 #1 Posted July 25, 2020 I need some help with my 1995 416-H . i'm not getting any speed in forward it just creeps along. It goes normal speed in reverse though. I changed the tranny oil and filter and checked the linkage . I don't know what to do next. Looking for ideas , thanks Share this post Link to post Share on other sites
rmaynard 15,602 #2 Posted July 25, 2020 Was the problem there before you change the oil and filter? Share this post Link to post Share on other sites
lynnmor 7,354 #3 Posted July 25, 2020 Look at the cam plate under the seat, does the motion lever push it till the cam is at the end of the slot? Share this post Link to post Share on other sites
stoneman61 1 #4 Posted July 25, 2020 Yes , the problem was there before I changed the oil. 1 Share this post Link to post Share on other sites
stoneman61 1 #5 Posted July 25, 2020 No the cam doesn't go to the end of the slot. Share this post Link to post Share on other sites
lynnmor 7,354 #6 Posted July 26, 2020 3 hours ago, stoneman61 said: No the cam doesn't go to the end of the slot. Then you need to find where the lost motion is coming from. Bad Heim joints, loose bolts or just very poor adjustments may be the cause. 1 Share this post Link to post Share on other sites
