TC10284
Scrape Blade Attachment
TC10284
Does anyone know if this scrape blade will attach to my 312-A? The scrape blade came with an older 520H I bought a couple years ago. I got the 312-A a few months ago.
Pics:
https://photos.app.goo.gl/7K79Qa4g7gwL3qTQ6
Stormin
I would think so. But you will need the rear attachamatic  for the rear axle.
TC10284
This?
https://www.ebay.com/itm/Wheel-Horse-Original-Rear-Attach-a-Matic/184369745238?hash=item2aed4b0d56:g:EdYAAOSwZehfFKT0
I have one of those (or maybe two) on another tractor and never was sure what they were. Probably the same 520H the blade came with.
Edited by TC10284
Stormin
That's the one. :handgestures-thumbup:
TC10284
Thanks!
Do I need the rest of the attachments (black parts) on the 312-A to mount it or is that not necessary?
Edited by TC10284
gwest_ca
That blade will fit the 520-H with a straight front axle
and a 520-H with the swept forward front axle if you add the extension kit to the blade A-frame.
Garry
Stormin
Don't know what those black part are for. Something a PO has made. In the centre of the frame is a plate that you attach a chain or flat bar to the lift arm. There's a hole just behind the deck peg on the lift arm.
 You need the lever and connections to the blade to angle it.
Take a look in the manuals section.
Edited by Stormin
gwest_ca
Click on the fuzzy picture
Garry
stevasaurus
You need to remove those black parts and the red one.  That needs to be clear so you have space to lift the blade.
Ed Kennell
Just a word of caution.    Your 312A with manual lift has the weaker Eaton 700 transmission that is best used as a lawn mower.
Your 520H has the stronger  Eaton 1100 transmission that is better suited for ground engagement implements.
