71_Bronco
1962 Lawn Ranger (Updated Thread)
71_Bronco
10 minutes ago, 305 said:
not to hijack this thread.....but would it be possible to use the 3 bolt axle flange from a later Lawn Ranger on these axles?
Probably, as long as they are for 1" axles.
I have a spare 5053 transmission (from a 1968 Commando 8) with the 5-lug hubs I'm going to swap in. I could just swap the hubs too if I wanted to as well, since they are the same transmission more-or-less.
Terry M
Not 100% ..but I’m pretty sure you can as the axels should be the same 1” diameter and length.  But the three bolt hubs could only be used with the three hole rear rims from 65-68 lawn rangers.
