drewd
Key Switch connections
drewd
Hi All,
I am installing a new key switch and redoing some of the wiring that is there (PO redid wiring and removed most if not all the safety switches and they are nowhere to be found).  Both the old switch and the new one have 6 connections.  I can trace all the wiring and will rewire and put in new fuse holders.
However, on the old switch had the G connection was just tied back in to the B connection.
  • My questions is when installing the new switch; where should I connect the G connection to?
Thanks!
gwest_ca
1987 416-8 with a M16?
Garry
Achto
The  "G" will be for the ground. Connect this term to a ground.
Important to know if you have a battery ignition or a magneto ignition on the tractor. There will be an "I" terminal on the switch if it is designed for a battery ignition. The "+" side of the coil will go to this term. Power will be provided to the coil through this term when the switch is in the on position.
If you have a switch for a magneto ignition there will be an "M" terminal on the switch. The kill wire from the coil will go to this term. This term will be grounded out when the switch is in the off position.
Edited by Achto
squonk
What model tractor?
drewd
9 minutes ago, squonk said:
What model tractor?
It's a 1987 416-8 with a Kohler M
Edited by drewd
added info
drewd
The old switch is tough to read but I do see an M.  That connection went to the White wire under the tin and then connected to the regulator/rectifier.  The A connection is Purple going to the regulator/rectifier as well.  I need to remove the side tin to see what else it is connected to.  I know very little re: electrical on motors so any help is greatly appreciated.  Thanks
953 nut
This post may be helpful.
Achto
Your 416-8 should have a magneto ignition unless some one changed it. If you follow the wire diagram that Gwest_ca & 953 nut posted for a magneto ignition tractor your new switch should work properly. If colors on the diagrams have different colors that you have then make sure that the wires are going to the proper places.
drewd
Thanks!  I have one last question.  The PO had a pigtail coming off the G connection back to B.  Can I run the G (ground) to the frame ground point of the Battery cable?  Or should I ground it separately to the frame?  Thanks again everyone!
Achto
Either one will be good.
drewd
Thanks all for the help!
  • Similar Content
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • morePEdal
      By morePEdal
      416-8 with Onan P216 Engine
      The good:
      *576 hours
      *Nice, clean deck (42”)
      *Nice Plow
      *Wheel Weights
      *Chains
      *2nd owner. 1st owner sold the house in 2020 and said he was getting too old so he included it with the house.
      *Original receipts and paperwork and manuals.
      *Receipt showing tune-up and changing from the deck to the plow in November 2021
      The bad:
      *The last time it was used was the winter of ‘21/‘22. It is currently set up with the plow.
      *Had trouble starting, when it started, it died after 4-5 seconds. He had a portable charger and it helped. We got it running, but when I turned it down to idle, it died.
      *I didn’t get a chance to test drive it because of this.
      *One front tire goes flat fast, one rear tire has a slow leak.
      *He is going to buy a battery before I look at it again on Friday so I can test drive it.
      What do you think is the issue? Is it the battery or fuel system?
      Do you have a way to verify what year this is with the ID number and serial number? Also, the ID number of the deck. I’ll upload pictures of the stickers.
      *He says his driveway has an incline so snow and ice would pool around his door opening so he got tired of his wheels spinning. He decided to pay for plow service. (Home is big and nice with a lot of land.) He also decided to get a zero-turn mower so that’s why this 416-8 wasn’t used since after winter ‘21/‘22.
      He’s asking $500.
    • Boyd
      By Boyd
      wheel horse garden tractor mower, rear discharge mowing deck & snow blower both in good condition and runs well. all the parts for the snow blower are with it.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
