roy 13 #1 Posted July 11, 2020 Wheel Horse 418-A has been in the family since I can recall, I;ve been using her to cut my less than an acre for about 15 years,. no idea what year she is. Anyway, lately, i've noticed her slowing down in forward , reverse is just fine & if I hit the brake the "handle" goes to neutral & she doesn't creep. I do have the original manual but, it covers the basic stuff like- changing oil, etc. Nothing about how to adjust trans issues. She has slowed down to a minor crawl in forward now, HELP! Is there a downloadable manual for the 418-A?? Thanks all in advance Roger- Ontario, Canada Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #2 Posted July 11, 2020 Your tractor is a 1987 model number 31-18KE01. Since reverse works you may have a buildup of debris preventing the full travel of the linkage for the forward. I would pull the seat and fender pan off a do a cleanup. I am not a hyrdo guy so don't know if this is the best manual for you or not. There are others. Let us know what you find. Garry 2 Share this post Link to post Share on other sites
roy 13 #3 Posted July 11, 2020 (edited) Thanks for the tip, I have cleaned out that whole area, it was quite full of debris. But, no joy with forward. I can see the linkage & notice when I put lever in reverse that bolt/washer arrangement is fully against the end of the groove in that plate, now if I shift to full forward, that bolt/washer is not at the end of its travel, meaning I can see about an 1" or more of the groove in the plate, that is showing. I'm assuming it should travel to the end of the grove in plate? Maybe I should add a picture, if my explanation is lacking?? Roger And, thanks for the File!! Edited July 11, 2020 by roy Share this post Link to post Share on other sites
953 nut 55,769 #4 Posted July 12, 2020 There could be a build up of grass clippings and debris in the tunnel preventing the mechanism from going all the way forward. Pull the cover off the tunnel where the motion control lever is and clean the tunnel out. Never know how many nutshells and grass clippings could be piled up in there. Share this post Link to post Share on other sites
lynnmor 7,353 #5 Posted July 12, 2020 Your linkage may be knackered, check and oil all joints. Share this post Link to post Share on other sites
roy 13 #6 Posted July 12, 2020 Looked like a Mouse nest in the tunnel! Cleaned it out well, Looks like the linkage isn't going the full distance in forward, I;m checking linkage/joints today, & Thanks for the tips, Stay tuned R Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,095 #7 Posted July 12, 2020 A wild thought but check the 6" x 7" plate at the rear of the tractor frame where the transmission bolts to the tractor frame. Loose or missing bolts or a cracked mounting plate could affect the transmission linkage. I don't think it happens as often on the hydro models. Garry Share this post Link to post Share on other sites
johnnymag3 2,521 #8 Posted September 8, 2020 What was the outcome with this linkage debockle............ Share this post Link to post Share on other sites
johnnymag3 2,521 #9 Posted September 8, 2020 Did you ever rectify this situation??? Share this post Link to post Share on other sites
Burnerman 758 #10 Posted September 9, 2020 Pull back hard on your brake pedal. Share this post Link to post Share on other sites
roy 13 #11 Posted September 16, 2020 (edited) Yes I did get her to go full forward, actually faster than ever ! In the tunnel, on the opposite side of the motion lever, the mechanism was jamming on what looked like a chestnut shell, I missed on the first cleanout. Motion control lever now goes full travel & all is well, thank you for the file you posted Garry . Now, I have to address why the big Kohler motor starts laboring when I get into longer grass, I have to increase throttle, never had to do this last season One of my 4 sons hinted he thought it might be the governor, which he might have slightly adjusted, but, thinks he didn't really mess with it, Oh, I see. Must be a "How to adjust the governor somewhere on here for the 418-A 18hp twin Kohler. Cheers Roy Edited September 16, 2020 by roy 1 Share this post Link to post Share on other sites
pfrederi 17,866 #12 Posted September 16, 2020 11 hours ago, roy said: Yes I did get her to go full forward, actually faster than ever ! In the tunnel, on the opposite side of the motion lever, the mechanism was jamming on what looked like a chestnut shell, I missed on the first cleanout. Motion control lever now goes full travel & all is well, thank you for the file you posted Garry . Now, I have to address why the big Kohler motor starts laboring when I get into longer grass, I have to increase throttle, never had to do this last season One of my 4 sons hinted he thought it might be the governor, which he might have slightly adjusted, but, thinks he didn't really mess with it, Oh, I see. Must be a "How to adjust the governor somewhere on here for the 418-A 18hp twin Kohler. Cheers Roy Section 6 page 49 Share this post Link to post Share on other sites
