Bill D
Transmission Dipstick Position
Bill D
I have had and seen couple of 8 speeds with bent, scraped any broken dipsticks.  The broken ones look like they got cut off.  What are they hitting inside the tranny and how do I prevent it?  Thanks.  Bill
ebinmaine
:popcorn:
tom2p
not sure of the exact issue you are referring to
but on some 300 series Wheel Horse tractors (and possibly 400+ series ?) with 8 speed that have seat springs attached to the seat frame - the spring on the right side (when sitting on tractor) can contact the top of the transmission dipstick handle (when seat is in down position and sat on) and then distort the dipstick and force the bottom portion into rotating mass
not sure which part or parts the dipstick will contact - but it can chew up the bottom portion of the dipstick
this issue and potential issue could have easily been avoided with a shorter transmission dipstick handle ... ? ... slightly raised platform where the springs contact when seat is down ... ? ... reduced seat spring diameter ... seat springs moved outwards slightly ... some of the above - all of the above - none of the above ... lol
this was a miss by the Wheel Horse engineers ... embarrassing miss actually
how to avoid ?
if you have issue described above - ensure seat frame spring does not contact the top of the transmission dipstick
sometimes can rotate dipstick slightly to ensure spring does not contact top of dipstick handle
Edited by tom2p
Bill D
Thanks.
johnnymag3
I think this is a situation where the seat spring causes failure
johnnymag3
why u still up?
horseyheaven
Bill, I have a 416-8 with a bent dipstick and it is even scraped up down on the end.  I straightened it out and put it back.  So far, it has stayed straight.
Ed Kennell
Here's what happened to mine after it git bent and rubbed the axle.102_2005.JPG.dabccdd308a8f0ee2638025685f6dcad.JPGe.
Edited by Ed Kennell
tom2p
  On 7/27/2020 at 1:51 AM, Ed Kennell said:
Here's what happened to mine after it git bent and rubbed the axl102_2005.JPG.dabccdd308a8f0ee2638025685f6dcad.JPGe.
have one just like it
lol
tunahead72
I hope you guys don't mind, I'd like to follow up on this conversation...
I just picked up an '88 310-8 with this same problem, it was one of the first things I noticed when I went to check it out.  The right side spring definitely interferes with the dipstick handle, and at first I couldn't even get the dipstick to seat properly in its tube.  I didn't notice if the bottom of the dipstick was damaged like some of you have mentioned, but I'll take another look tomorrow.  I was eventually able to get it to seat properly, and rotating it out of the way of the spring might help.  But it does look like a bad design, and I started wondering...
What do those springs actually do, and are they even necessary?  They don't seem very stiff, so if I were to remove them, would the rubber bumpers be enough to absorb uncomfortable bumps to my rear end?
I see two holes drilled into the bottom of the seat plate, further back and to the outside a bit.  I wonder if the rubber bumpers and springs could be moved there without causing any problems.
On a related topic, is the gas seat spring on these tractors really useful, or necessary?  The one on this "new" tractor doesn't seem to do much, it may be dead.  My '86 310-8 doesn't have the gas spring or the large springs, I'll have to check it tomorrow to see how the two tractors are different.
Any insights would be appreciated.
lynnmor
The springs lift the seat off the seat switch, a safety feature.
The gas spring holds the seat up while you fuel, check oil, etc.
  • Similar Content
    • davem1111
      By davem1111
      I have this 520-8 that needs some love and restoration expertise, and I don't have the time or gumption to take on this project and give it the TLC it deserves.  Local pickup near Bloomington, IN only.... (almost - I might be able to meet somewhere but not too far, and I don't have a trailer.)
      The Onan P220 runs, but not well. I repaired the seal on the intake manifold, replaced the carb & spark plugs, adjusted valve clearance, and tried adjusting the governor, but it still surges. It has the swept front axle but does not have reduction steering. As far as I know, all is original, and the hour meter is at 610.
      Several attachments could be included in the deal if desired, for a bit extra. Either a 60" SD or 48" SD deck, single stage snowblower, and/or snow plow blade (would need to get extension kit for front wheel clearance).
    • Horse Digger
      By Horse Digger
      Ok, so I've found out just where the oil is leaving the transmission on my C120 8 speed from around 1974.
      Removed the brake "drum" and discovered a thin ring around the axle, is this part of the seal and can this be replaced without tearing the whole transmission?
      I found several posts & youtube videos about replacing axle seals, but none about the brake axle seal...
      Since this is the lowest axle, the oil-level is to low to determine if axle seals are bad too...
      I'm uncertain of what transmission I've got so trying to find the manual for it has been hard, someone who can help?
      Yanking the axel I can just about feel a play, is this OK, or should I replace the bearing too?
    • N3PUY
      By N3PUY
      This winter while plowing my C125 stop like something in the transmission was binding.   It happened 3 times but otherwise worked just fine.  So today I thought I'ld better check it out.
      After removing the right case half I got to look inside.  A BOLT?    How did a bolt get in there?
      All 4 bolts were in the diff.    Well,  3½ bolts!    One diff bolt is broken and the other 3 are loose.    And the diff housing is chipped.
      There is a little more damage done ... this gear has chipped teeth.   Might have been where the bolt got to it.
      And this long gear has 3 worn teeth!  Why?
      And how did this spacer loose a piece?
      Well, now it's time to hunt for a few parts.  A friend has a parts transmission that might help me out.
    • DuchApl
      By DuchApl
      I couple years ago I bought a C-100 for parts. So this year I decided to re-acquire all the parts I put on the first c-100  and make a  Frankenstein c-100.
      Anyway-  before I started anything, I tested out the tranny running it off the PTO from the other tractor. Everything looked fine - all gears worked, pretty smooth shifting. So, I go to put it all back together and  find that the left to right travel on the Hi-Lo shifter is much too long once it's installed. Trying to shift into high or low is now restricted by the width of the tunnel, not to mention when the shift pattern plate is installed.
      Before I go crackin' this thing open, is there any adjustment that can be made externally? What might cause this - and am I doomed to putting a fork in it?
      Thanks in advance,
      Pete
