kthomas62
Governor Question
kthomas62
Good evening all!
Needing some expert advice please! Please pardon me for not using the correct terminology for some of these parts. Hahaha.
So one of my 414-8's had some kind of jacked up muffler on it and I was very lucky to find the correct one for $35.00. I also needed the exhaust elbow, that mounts to the engine, and the muffler U-clamps to. This said, In order for me to have clearance to screw it into the engine, I had to remove the governor rod from the shaft.
I reinstalled it and started the mower and I believe it idles at about the same RPM that it always did, but now if I push the throttle all the ways up, it seems to be running much faster than it's original governed speed, so in order for it to run about where it did, it needs to be at about 1/2 or 3/4 throttle.
I assume that I have something out of adjustment now, so wondering what I need to do, in order to adjust the high throttle back down.
Thanks in advance for any advice!!
Kevin.
Edited by kthomas62
kthomas62
I think I may have figured out what I need to do. Will try to adjust it tomorrow after work and see what I get.
Kevin
JAinVA
Loosen the governor arm clamping bolt and nut so that the arm rotates on the shaft.With pliers rotate the shaft CCW as far as it will go.Pull the carb linkage so that the arm is going as far CCW as possible .While holding both the shaft and arm as far CCW as you can tigthen the arm bolt and nut.
  • Like 4
kthomas62
Thanks Jim!
That's exactly what I am going to do tomorrow after work. I found a good video on You Tube showing this adjustment!!
Kevin
WHX??
You kind of have to have three hands to do it.
Good old you tube what did we do before that!?!?
The manual I guess!
Guv adjust on page 5.1
Engine Kohler K91 K141 K161 K181 K241 K301 K321 SM 1972.pdf
bottjernat1
This video is very helpful.
prondzy
To rotate and hold the govenor shaft ccw i use a small alligator vise grips so you can use your hands to hold the governor arm and tighten the 1/4-20 bolt to hold it on the shaft
kthomas62
Got it done. Took about 2 minutes today after work and it's back to running like it should! Simple operation!
Thanks guys!!
Kevin
  • Like 3
