71_Bronco
Tripple Pulley Removal
71_Bronco
Going to be working on my 8hp Commando 8 motor soon, and one thing I'm not looking forward to is removing the tripple pulley on the crank of the motor. There is no drilled & tapped holes to thread in puller bolts.
Does anybody have any hints or tricks to getting this off?
Thanks!
Pullstart
If you can start some wedges in there, like construction shims... and work up to pickle fork / tie rod tools... you might be able to tap it off the crank.  Shim from both sides, to keep the wedge pressing parallel on the pulley.
bc.gold
Thanks!
Bearing splitter is made for such a task.
  • Excellent 2
bc.gold
Thought you were taking a nap.:ychain:
  • Haha 1
Pullstart
rumble strip....  just outside of Memphis on US-55!
  • Haha 1
ebinmaine
I used a 3 jaw puller. Caught one of the grooves that was flat toward the puller. Got it all set up then wrapped the puller with a band clamp so it couldn't come off.
That was before I had a set of pullers like mentioned above...
JoeM
Wedges and tapping the shaft lightly. Some of those pulleys had a thicker area between groves, if you use a puller make sure you are behind the thicker ring.
WHX??
Polish the exposed crank and use plenty of lube.
clueless
Okay everybody let's not go there :snooty:
  • Haha 5
squonk
Bearing separator and puller on the separator. Jaw puller can damage the pulley
WHX??
I never even went there till you just said something! :lol:
  • Haha 3
squonk
Here's the set up:
953 nut
:text-yeahthat:    Mike's @squonk set up in the previous post is the  way to go. I use an air impact gun to run the bolt in on the puller and if it isn't moving give the end of the puller bolt a couple of blows with a BFH tool to shock it. Some times there will be enough rust between the pulley and shaft that you will need to heat the pulley to get it moving.
WHX??
Mike you need to clean your crank before you start pulling on it & squirt some lube down that screw hole. :)
  • Haha 1
squonk
Came right off. Grey stuff on threads is lube. :helmet: Couple raps with the Dee-Walt 3/8” impact and it was in my hands
Edited by squonk
