Pullstart 62,787 #1 Posted July 5, 2020 In 8 hours, I’ll wake up and pack up the gear from camping this weekend, fill up the chicken and cat food and water and the family and I are heading to Dallas Fort Worth. We plan to be back in Michigan Tuesday night. We hope for safe travels and no forsaken road blocks. The dolly is greased up, tire pressures at 50 psi as recommended and we have roadside stuff in a pile to be loaded before we go. Here we come Norman Jr! Thanks in advance for your engine and other goodies to make Norman purr cool again! 4 1 Share this post Link to post Share on other sites
D_Mac 8,593 #2 Posted July 5, 2020 (edited) You can load my Speedanza in the back of the truck on the way back from Texas, just take a small detour ! Safe travels. Edited July 5, 2020 by D_Mac 1 2 Share this post Link to post Share on other sites
Mickwhitt 4,584 #3 Posted July 5, 2020 Happy trails Kevin and family. Take it easy and Nirman jnr will be home before you know it. 1 Share this post Link to post Share on other sites
Stormin 9,981 #4 Posted July 5, 2020 Safe journey and above all stay safe. 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,490 #5 Posted July 5, 2020 Fair winds and following seas... 1 Share this post Link to post Share on other sites
ebinmaine 67,271 #6 Posted July 5, 2020 Safe travels. Post pics. Enjoy the journey. Good luck.. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,300 #8 Posted July 5, 2020 Good luck! What are you towing it with? That’s gotta be a 6000-7000 pound truck, just a guess (Maybe I shoulda googled it) 1 Share this post Link to post Share on other sites
Pullstart 62,787 #9 Posted July 5, 2020 1 hour ago, Sparky said: Good luck! What are you towing it with? That’s gotta be a 6000-7000 pound truck, just a guess (Maybe I shoulda googled it) Yugo! The Suburban has a max trailering package, rated at 8,000 lbs. I had an ‘01 crew cab 4x4 Powerstroke that came across the scales at 7450, this is an extended cab 2wd and I assume it to be in the 6500-7,000 range. We don’t expect to make any land speed records on the trip home, just constant progress at any speed we feel is comfortable. 5 1 Share this post Link to post Share on other sites
SylvanLakeWH 25,490 #10 Posted July 5, 2020 3 hours ago, pullstart said: We don’t expect to make any land speed records on the trip home, just constant progress at any speed we feel is comfortable. So.. your thinking about 1st or 2nd gear low range on a WH...? Maybe 1 - 2 MPH if the wind is to the rear? Remember - You need to factor in the weight of the Ho Ho's... 1 3 Share this post Link to post Share on other sites
bc.gold 3,403 #11 Posted July 5, 2020 (edited) How many lugs on the dolly rims, how much weight is going to be at rest on the dolly axle, ball size and does it have brakes, electric or surge, the truck yer going fer has a blown automatic, drive shaft needs to be removed. Load Range: C (6-ply) Max. Capacity: 1825 lbs. each Overall Diameter: 27.3" Maximum PSI: 60 lbs. Rim Finish: Painted, Spoke Pattern, 3-1/8" Center Hole Lug Pattern: 5 Lug on 4.5" Bolt Circle Rim Pattern: Spoke Tire Diameter: 15" Rim Width: 6" Rim Finish: Painted 6 lug on 5.5" Bolt Circle, 4.25" Center Hole Weight Rating: 2,830 lbs. NOTE: Rim rated to 80 PSI Edited July 5, 2020 by bcgold Share this post Link to post Share on other sites
Pullstart 62,787 #12 Posted July 5, 2020 Arcola, IL Dairy Queen stop! All is going well! 2 1 Share this post Link to post Share on other sites
WHX?? 48,775 #13 Posted July 5, 2020 You just not better bust anything else up you can't make it here next weekend ! 1 1 Share this post Link to post Share on other sites
bc.gold 3,403 #14 Posted July 5, 2020 (edited) 31 minutes ago, pullstart said: Arcola, IL Dairy Queen stop! All is going well! We'll keep an eye open for ya., Arcola, IL- Local Traffic Cams Edited July 5, 2020 by bcgold 1 4 Share this post Link to post Share on other sites
Pullstart 62,787 #15 Posted July 6, 2020 Benton, IL... switched off drivers for a bit. I’ll nap in the back and help with 3rd shift! ETA to DFW is 5:30 am... soon need to hurry. We’ll spend the day there, get a good night’s sleep and head home Tuesday early! 2 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,314 #16 Posted July 6, 2020 Safe travels Kevin, don't be getting any ideas of wrangling any Horses while you're down this way, we need to keep the few we have down here 1 Share this post Link to post Share on other sites
Pullstart 62,787 #17 Posted July 6, 2020 We’re in the middle of Arkansas... I’m supposed to be sleeping... but I can’t ever really sleep in a vehicle... just cat naps. Inside of 400 miles to get there! Share this post Link to post Share on other sites
Pullstart 62,787 #18 Posted July 6, 2020 I love them girls! They won’t ever admit, but they’re best friends too. They travel like little troopers. We’re 800 miles from home and have stopped twice for bathroom breaks. Not a complaint from either one. 4 3 Share this post Link to post Share on other sites
Pullstart 62,787 #19 Posted July 6, 2020 We took a two hour snooze on the side of the on-ramp with a couple other truck drivers. We’ve got about 150 miles to go.... I guess my 1000 mile mark was closer to 1150 each way 5 Share this post Link to post Share on other sites
WHX?? 48,775 #20 Posted July 6, 2020 Dan always jokes the only time he can sleep in a moving car is if he's behind the wheel! 1 7 Share this post Link to post Share on other sites
Pullstart 62,787 #21 Posted July 6, 2020 We’re here! Well we are just a few miles from there! But first, Waffle House! A delicacy you won’t find in Michigan... Great coffee, full bellies! 3 2 Share this post Link to post Share on other sites
Achto 27,502 #22 Posted July 6, 2020 44 minutes ago, pullstart said: But first, Waffle House! Leave the waffles. I'll have hashbrowns - covered, smothered, chunked, diced, peppered, & capped please!!! Safe travels Kevin 1 2 Share this post Link to post Share on other sites
Pullstart 62,787 #23 Posted July 6, 2020 Made it! We have a bit of time to go see Texas! 5 3 Share this post Link to post Share on other sites
johnnymag3 2,515 #24 Posted July 6, 2020 Awesome!!!!! Nice run Be safe and you will be fine !!! John 1 Share this post Link to post Share on other sites
Mickwhitt 4,584 #25 Posted July 6, 2020 Fantastic updates kev, glad the girls are enjoying it, if looking a bit sleepy lol. Stay safe Mick 2 Share this post Link to post Share on other sites
