ebinmaine
A new member of the herd. C160/Tecumseh.
ebinmaine
Note for future reference:
www.enginesandmagnets.com
  • Excellent 1
ebinmaine
Just wanted to take a minute and say I got to meet the man responsible for the above mentioned website.
@Ed Stoller
Super nice guy and very helpful.
Ed was at @stevebo 's Meet n Greet a few weeks ago.
I bought an ignition kit from Ed for future usage on this project.
Also just the other day I had the extreme luck and opportunity to add ANOTHER 1974 C160 Tecumseh engine tractor to my herd.
That one does run. I'll be doing a service to it and immediately putting it to use.
RandyLittrell
It looks like the hood hinge is a couple inches tall that others, is the dash stand taller as well to cover the OHV?
Randy
ebinmaine
Randy
Good eye Randy.
Hood hinge only.
Not sure of the actual size difference.
The dash stand is standard height.
Once I get the second Techie powered tractor running and driving I'll park em side by each for a photo opp.
Lee1977
That's a tall order getting two Teckie's running at the same time, I'm not sure if that has ever been done before.
Edited by Lee1977
  • Haha 2
ebinmaine
2 minutes ago, Lee1977 said:
That's a tall order getting two Teckie's running at the same time, I not sure if that has ever been done before.
I'll take that challenge. 😀
  • Similar Content
    • jledonne
      By jledonne
      1966 Lawn Ranger PROJECT
      L-106 Lawn Ranger with non-running Tecumseh H60, 6hp.  Engine lost compression, reads 25 PSI.  No visible external damage to block or cyl. head.
      Mostly original, one owner tractor w/ 32” mower deck and 32” snow blower (STR-3240) both serviceable.
      Very good sheet metal.  Original seat has tears.  Newer carburetor, original included.  New recoil starter (uninstalled).  Replacement front wheels/tires.  Originals included, one has broken hub.  Original rear WH tires.  Two sets of tire chains, one new w/ tensioners.  Box of small parts and original documents.
      Good candidate for restoration or repower conversion.  $275 OBO.  60+ high-res. photos online, PM or call/text 610-248-6471 for link.  Located in PA, 18072.
    • SethL1984
      By SethL1984
      312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
      417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
      (1) 42" RD with mule drive. Cuts well!
      (1) 48" SD with mule drive.
      (1) 37" SD.
      (1)  48" snow plow. 5 way blade position I believe.
      Several other parts/WH odds/ends. One tractor does include the weights and chains.
      Parents are moving and, unfortunately, need to thin the herd!
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • Ralpho711
      By Ralpho711
      I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different.  Any help is greatly appreciated. I'm brand new to the site and think its great!
    • Nathan
      By Nathan
      Can anyone help finding year of this tecumseh motor off a 603. I need a carburetor.
