ebinmaine
A new member of the herd. C160/Tecumseh.
JAinVA
Good score Eric.Looks like you will busy for some time!
  • Like 4
WHNJ701
hopefully you got spark!  $$$$
The Tuul Crib
So many projects so little time find yourself not knowing how to rhyme. Where am I going with this doesn't matter. Nice find I'll be watching!:popcorn:
Edited by The Tuul Crib
ebinmaine
I'd had that thought too.
If not I'll do a GM 4 pin module conversion.
  • Like 4
The Tuul Crib
Hope that magneto it's good don't mean to be a damper on it but they're hard to find.. If you do find one you will know it because your wallet with me a little thinner.
ebinmaine
Nope....
No worries.
That's what @jabelman was talking about.
There's a way around it...
WVHillbilly520H
4 minutes ago, ebinmaine said:
Nope....
No worries.
Thank goodness for the General, GM that is huh?
  • Haha 2
The Tuul Crib
can they be recharged.?
ebinmaine
Agreed.
But it uses a Ford abs sensor too.
:lol:
Nah....
They can be replaced with a hall sensor, GM module, and a coil.
  • Confused 1
Jaydubz83
Sweet Baby Jeebus!!!
:wicked:
Hey, wanna trade seats?  I have one that is in "gently used" condition :lol:
  • Haha 2
Sparky
I swear I’ve seen that one before somewhere :lol: . Glad to hear the motor isn’t locked up.
 (For those that don’t know I live right next door to Tony)
  • Like 4
  • Thanks 2
ebinmaine
@WVHillbilly520H @The Tuul Crib
Here's the setup. Not sure if I can use it.
  • Thanks 4
Docwheelhorse
Beautiful, I figured it was packed. I wanna see the old girl breath fire again.
Nice to meet you and a nice area of Maine
Good Luck--push hard and have it going for PA in '21... push REAL hard and make Stevebo's 10/20
Tony
  • Thanks 2
ebinmaine
Tony
Thank you sir.
Nice to meet you as well.
We sure would love to see the Big Show....
roadapples
I'll be following along. I have a 68 raider 10 with same issue. Otherwise near perfect condition...
ZXT
Nice looking new machine! I knew you could get a Tecky on a C-160, but that's the first one I've ever seen. My dad picked up an OH-160 the other day for nothing, not knowing what it was because of it being OHV and the markings gone off of the shroud.. He almost took it back but I made him keep it.. Figured it would make something of mine move if nothing else.
If it has ignition issues you can always do a Kohler conversion :hide: :lol:
SylvanLakeWH
:popcorn:
Just one question:
What’s Trina’s estimate on her completion of the rebuild?
:ychain:
  • Haha 6
Pollack Pete
Pretty nice C-160.Never knew a few were built with an OHV Tecumseh.I've never seen one.Til now anyway.It's really something how little furry critters can make an engine appear seized.Like one of the old cartoon caracters used to say...….I hate those meeses  to pieces.Have fun with your new toy.
ebinmaine
7 hours ago, ZXT said:
If it has ******* issues you can always do a FM ZC 3 conversion
Hhhmmmmm...
:woohoo:
1 hour ago, SylvanLakeWH said:
:popcorn:
Just one question:
:ychain:
We did actually talk about that...
So here's the current plan:
Even though the Military Display show at Owls Head was cancelled Trina still wants to build herself a Military Tribute Tractor using the 856 gifted to her by @Herder Adam.
I want the Charger Hydro done ASAP so can get some run time on it use it for winter.
Then Colossus so it'll be ready for spring '21 forestry season.
Then... This ole girl is next in line.
Not to mention Trina's house painting project.
And all the other 74 million things she does.
So it'll be a bit.
:techie-hourglass:
  • Haha 1
ebinmaine
Oh by the way... @WHX24 will be happy to know this C will be a real proper colored Red restoration.
  • Excellent 3
  • Haha 3
AMC RULES
:rolleyes:  YAY Trina!  :greetings-clapyellow:
  • Excellent 2
  • Haha 1
953 nut
So       :confusion-confused:      While Trina is doing all this work            :tools-hammerdrill:       Will you be able to keep up with the photos and commentary?          :wwp:
  • Haha 6
ebinmaine
I dunno man.... She.  BUSY.
  • Haha 1
AMC RULES
:scratchead: What else would he be doing?
  • Haha 1
  • Similar Content
    • SethL1984
      By SethL1984
      312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
      417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
      (1) 42" RD with mule drive. Cuts well!
      (1) 48" SD with mule drive.
      (1) 37" SD.
      (1)  48" snow plow. 5 way blade position I believe.
      Several other parts/WH odds/ends. One tractor does include the weights and chains.
      Parents are moving and, unfortunately, need to thin the herd!
    • Brian33
      By Brian33
      Hello,
      I am hoping someone can help my. I recently acquired a c160 for the engine for another tractor. So I did a motor swap and wanted to see what the hydro was like. I put a plow on it C-160 (which now has a 12hp engine on it). I did a quick test run and everything was good. I drained the fluid and change the filter (Napa 1410 filter and sae 30 transmission fluid as it stated to only use this fluid on the tractor.) everything was working great after the fluid change. I plowed two driveways and the sidewalks near my house... all the sudden the tractor would not go forwards or in reverse. I tried to pick the plow up and nothing... I checked my drive belt it was turning like it should. I started to push the tractor and the rear was engaged so it would not move. Of course I was 400’ from my driveway and the plow was down which made it fun. I put the tractor in forward and started to push it and the thing took off. So I hopped on and took it to the front of the garage. I put it in revers and it cut out again so I pushed it in the garage. Today I went out to check the tow valve. I took it out and cleaned the threads up put it back in and it did not change anything. According to the dipstick I have the proper amount of fluid in it. I did have a drip that I fixed on the cylinder still nothing... does anyone out there have any tips to help me out? I’ve never had a transmission like this only manual transmissions. The model of this transmission is the sundstrand 90-1140.
      Any help would be greatly appreciated.
      Brian
    • Ralpho711
      By Ralpho711
      I have a 1976 C-120, 8 speed, that has had a bad rear axle key way for about 35 years.The plastic steel we put in to keep things together finally gave up the ghost last year. I tried some welding but that hasn't held up either. My question is will the rear axles from a C-81 8 speed fit in my transmission? According to the parts lists I found on this site, both trans have 1 1/8" axles and 8 pinion diffs, but the axle part numbers are different.  Any help is greatly appreciated. I'm brand new to the site and think its great!
    • Nathan
      By Nathan
      Can anyone help finding year of this tecumseh motor off a 603. I need a carburetor.
    • ebinmaine
      By ebinmaine
      I don't have pictures yet but I can get some later. I know that will be helpful but I forgot to take them last night.
      So here's what I know.
      When I bought my c-160 last year it came with a plow. It was delivered to my house and the plow was not mounted on it. I never saw this particular plow on that particular tractor.
      The plow I have is 42 inches wide and has a full frame as most of them do.
      The angle lever has the Z shape to it, NOT a straight stick of metal, and also bends slightly back towards the operator.
      When I am pulling the angle lever towards me to change the angle of the plow it contacts the brake lever.
      Any thoughts?
