Hoosier Dave 2 #1 Posted June 28, 2020 This is the first time I put the deck on myself..... cuts fine. However, I have to use the highest setting to cut 3" or so.... I cant figure out how to leave the grass longer. I'm not sure I have the deck properly mounted. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #2 Posted June 28, 2020 Welcome to the forum. Here is an operator manual Garry Share this post Link to post Share on other sites
peter lena 8,583 #3 Posted June 28, 2020 agree with gwest above on operational file, also found on mine , 42" r/d deck ,that a larger rear wheel helps for a higher lawn , like a 6 " wheel. pete Share this post Link to post Share on other sites
Hoosier Dave 2 #4 Posted June 29, 2020 20 hours ago, peter lena said: agree with gwest above on operational file, also found on mine , 42" r/d deck ,that a larger rear wheel helps for a higher lawn , like a 6 " wheel. pete Hi Again, When I mounted the deck there is a part of the "hitch" that has a steel piece with a V cut into it. Can you tell me where that V should be at? The steel rod with the spring on it? or the other steel rod? Share this post Link to post Share on other sites
lynnmor 7,302 #5 Posted June 29, 2020 1 hour ago, Hoosier Dave said: Hi Again, When I mounted the deck there is a part of the "hitch" that has a steel piece with a V cut into it. Can you tell me where that V should be at? The steel rod with the spring on it? or the other steel rod? the other steel rod As you have seen, the manual leaves a lot to be desired, the rod with the spring isn't even shown in Figure 6. Since you want maximum height, level the deck with minimal slope front to rear. Share this post Link to post Share on other sites
dcrage 627 #6 Posted June 29, 2020 Your complaint wanting to cut higher is very common for WH decks. I assume people didn’t cut lawns as tall in 1950- 1990s as they want to now. Sounds like your deck is working correctly. Share this post Link to post Share on other sites
tunahead72 2,411 #7 Posted June 29, 2020 @Hoosier Dave I know somebody has posted some really good photos for this whole process, including what you're aiming for with the "V" (yes, the other rod). @daveoman1966 maybe? Share this post Link to post Share on other sites
