Ford120 0 #1 Posted June 27, 2020 I recently acquired a 1967 1257 with a steering wheel that is broken at both spokes. As usual, it was "fixed" with wire and electrical tape. I know that the same two-spoke wheel was used by Jacobsen on its own-braded tractors as well as the ones it produced for Ford and Minneapolis-Moline. Ariens also used this same wheel on some of its models. While trying to locate a good, used wheel, I stumbled across something else that might work: the Farmall Cub had a steering wheel that was 15 inches in diameter and mounted on a 3/4" keyed, shaft. All of that matches the WH wheel. Does anyone know if a Cub wheel can be used on these tractors? Or does anyone know where a good, used wheel might be hiding? Thank you. Share this post Link to post Share on other sites
ebinmaine 68,885 #2 Posted June 27, 2020 Not sure about the options you've listed but I like the logic... 15" wheel would be nice for added leverage. If you're not too concerned about being exactly original then many Wheelhorse steering wheels should work. Lincoln at A to Z tractor in PA might have one. Or, throw an ad in our wanted section once usable alternatives have been found. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,136 #3 Posted June 27, 2020 The original wheel for the 1257 was part number 4875 Garry Share this post Link to post Share on other sites
Lee1977 6,872 #4 Posted June 27, 2020 (edited) AGRI Supply has a 14 3/4" Cub. steering wheel with a 3/4"keyed mount for $19.95 + shipping. Edited June 27, 2020 by Lee1977 Share this post Link to post Share on other sites
johnnymag3 2,532 #5 Posted June 27, 2020 6 hours ago, ebinmaine said: Not sure about the options you've listed but I like the logic... 15" wheel would be nice for added leverage. If you're not too concerned about being exactly original then many Wheelhorse steering wheels should work. Lincoln at A to Z tractor in PA might have one. Or, throw an ad in our wanted section once usable alternatives have been found. Eric, Ive been searching for one of these, and I dont think any exist... Time seems to have run out on these steering wheels....😒 1 Share this post Link to post Share on other sites
johnnymag3 2,532 #6 Posted June 27, 2020 If you find a look alike, maybe the center cap can be used, or a decal installed ? Not sure if a Repro has been made or not Good Luck, I will follow this to see if you found one...GOOD LUCK and Welcome 1 Share this post Link to post Share on other sites
