peter lena
sudden mower deck noise
peter lena
my decks are very quiet, so when a rattling type of noise suddenly came up, i quickly dropped the deck and looked around, spindles were smooth and quiet . found the center spindle drive pulley to be a little loose , causing the rattling sound against the keyway , examination showed no damage to keyway or pulley. i had tightened everything up after rebuild ,re tightened with electric impact and 6 point impact socket . everything smooth and easy turning , added a couple of drops of  75x90 gear oil to the idler pulley bearing , when the bearing area bubbles up , its sucking in the lube. remounted deck and the quiet is back, staying after it , pete
  • Heart 1
stevasaurus
Good man!!   Hear noise, stop horse, find noise, fix noise, check for more issues, a little oil, back on the road.  Beverage is still cold.  :orcs-cheers:
squonk
I have had an issue with certain fasteners using an electric impact does not tighten it completely. Recheck by hand or torque wrench.
( No hub clamp on a sewer pipe above the boss' desk was the first time) :helmet:
Edited by squonk
