71_Bronco 1,072 #1 Posted June 24, 2020 Anybody have a drawing off-hand for the 2 plates I've seen to reinforce the fame where the transmission bolts on? I had it written down somewhere, a pair of strips of metal with holes to match the 4 mounting holes. Cant seem to find it. Thanks Share this post Link to post Share on other sites
ebinmaine 68,879 #3 Posted June 24, 2020 I keep a copy of that thread in my email. I think that will have what you need in it. 1 Share this post Link to post Share on other sites
Lee1977 6,871 #4 Posted June 24, 2020 (edited) The top is 1 1/2" x 6 1/8" long x 1/4 thick . The spacing is 13/16" center of hole 4 1/2" to center of other hole and another 13/16". The bottom one is 6 5/8 " long x 1 1/2' with 1 1/16 center of hole 4 1/2' center of other hole and another 1 1/16"/. All holes centered in the 1 1/2" width. If this is has the ridges in the trans plate I ground the edge Edited June 24, 2020 by Lee1977 Share this post Link to post Share on other sites
daveoman1966 3,762 #5 Posted June 25, 2020 The two FLAT plates shown above will do little to correct for cracks in the CORNERS of the frame plate. I use 3/16 or 1/4" thick angle iron to make / repair plates to fix not only the FLAT, but the CORNERS as well. 4 Share this post Link to post Share on other sites
Lee1977 6,871 #6 Posted June 26, 2020 (edited) 5 hours ago, daveoman1966 said: The two FLAT plates shown above will do little to correct for cracks in the CORNERS of the frame plate. I use 3/16 or 1/4" thick angle iron to make / repair plates to fix not only the FLAT, but the CORNERS as well. The corners crack because the plate cracks around the four mounting bolts first. I have the corner support too on my Wheel Horses. I didn't fix a busted transmission I reinforce a good one. Edited June 26, 2020 by Lee1977 1 Share this post Link to post Share on other sites
