oldoutboard
tire chains
oldoutboard
I have a C-101 Wheel Horse tractor with the snowblower attached and would like to know which tire tread (tractor lug tread or Turf tread) would work better in snow  I have both tire treads on rims and want to buy a set of tire chains for the tread that works best in snow and on a tar driveway. Your thoughts Thank You
ebinmaine
I've run both turfs with chains and ags with chains and I don't see any difference in traction on the snow and ice. Ag/bar type tires without chains work far better in the mud than a regular turf tire of course.
But on the ice and snow my experience shows it's the chains that do all the grabbing and the tire is merely holding the chain in place.
LARGE amounts of WEIGHT are going to be the key to traction in the snow.
Get your tires liquid-filled. I use and recommend Rimguard.
Get as much steel weight as you can.
build a box for the back as well if you like.
The heavier the better.
If you have an asphalt driveway that you'd like to keep in decent shape your best bet is rubber chains.
Ed Kennell
If you are definitely going to use chains, the turf tires would work best.  Turfs  will keep more of the chain in contact  than a ag tire.
Oh, and :text-welcomeconfetti:to the :rs:
Edited by Ed Kennell
stevasaurus
Chains = turf tires for sure.  :handgestures-thumbupright:
oldoutboard
Thank"s everyone all for the fast reply's, I'm going to leave the turf tires on and buy chains for them. I never knew they made rubber chains, I can see them maybe being better for a tar driveway than steel chain but I think I better stick with steel.
