Razorback
Something better than a lift cable
Razorback
Is there such a thing as converting from a lift cable to either a lift bar or chain?? (or something else I have not thought of?) This is on a 1974 C-160.
Pullstart
We’ve talked about snaking a 3/8” rod up through the tunnel, but I can’t recall anyone showing pictures of such a thing..
Razorback
I'm gonna have to look at it and see if I can "make something fit".
(Remember the old Midas muffler commercial??? " My buddy, Leroy, here will MAKE it fit.")
Edited by Razorback
  • Haha 3
ebinmaine
I've not tried it. I remember some mention of the angles not being quite right to run a solid link through the transmission tunnel without causing excessive wear someplace.
'course my memory is a bit.... What were we sayin again?
:lol:
  • Haha 1
953 nut
A solid rod would present a couple of problems. The rock shaft on your lift makes an arc as it moves and the lift at the rear of the :wh: also makes an arc, both of which are lower than the top of your transmission. A bracket could be fabricated to fit a small 12 volt linear actuator to the lift.           :wwp:   when you do it.
  • Like 4
bottjernat1
  • Haha 1
squonk
Depends on the model. I think it was Bud Andrews had a solid rod maybe 5/16" to the slot hitch on a 60's tractor.
Lee1977
Are you breaking cables?
Razorback
I broke one last year..... just got me wondering.....
ebinmaine
6 minutes ago, Razorback said:
last year
How old was that one?
Lee1977
You best option is to install a chain to the equipment and attach it to the tractor to take the tention of the cable when it's all the way out. if you broke it while lifting not a lot you can do about that.
Cvans
I don't remember having issues with the cable. It was missing when I got the tractor and don't remember how I made it but it lifted some pretty heavy loads.
I'm afraid that running a rod following the track of the cable would be very difficult to do.
8ntruck
I'm watching this thread with some interest. My 14-8 has the rock shaft and cable tube, but no cable.
Razorback
No telling how old it was. Maybe original.
Goldnboy
Here is how it works
ebinmaine
I don't have any tractors at home with cables to lift.
I do work for a living with a crane and also proper securement of variable loads to a flatbed truck.
We use WLL which stands for Working Load Limit.
I'm not sure what size a horse cable is so I'll use 1/8" as an example.
The WLL is 400 pounds or so with a break strength of around 2000 pounds.
That's a Safety Factor of 5:1.
Age, corrosion, exceeding the "stop point" will all cause catastrophic failure of the cable.
Another cause not often considered is metal fatigue.
Minor flexing of steel causes very little fatigue but Will eventually snap the cable.
Add a little rust....
Where as that cable style goes through a tunnel that isn't meant to deal with wear caused by friction it might be best to keep the cased cable and add a very strong spring to the end to prevent exceeding the "stop point".
Razorback
Curious if that will work on my C-160 8-speed.... will look into it.
Razorback
7 hours ago, bottjernat1 said:
Funny!
The one I remember is Midas.... two guys in front of a small car on a lift. Big guy "Leroy" is holding a huge, long muffler. Customer says, "Are you sure it will fit?" The brains of the two workers says, "My buddy, Leroy, here will MAKE it fit."
ebinmaine
I'm thinking it should.
The lever and end lift point should be in similar locations...
Keep us posted.
WVHillbilly520H
This is the linkage and top link or rear rockshaft on a Cub Cadet Original that I grew up on I'm sure with a little bit of Hillbilly ingenuity other solid rear lift lever/links could be on order of this...
  • Heart 2
Razorback
Yes,I also have a Cub 123. I really like the lift mechanism on that GT..... very strong and capable.
