71_Bronco
PTO Driven Pestiside Sprayer?
71_Bronco
Was spraying my outside patio today with weed killer. I have one of the small gallon sized bottles that you pump the top, then spray with the wand.
Was thinking it would be cool if you could rig up a larger tank to the front / hood, and have a PTO driven pump to be able to spray.
I saw the post from another member about the system that goes through the exhaust, but I'm thinking more of a spray wand / nozzle with just a pump driven by the PTO and a belt.
Does such a thing exist?
8ntruck
There was a Wheel Horse on CL last fall that included some sort of front mounted spray rig.  Didn't pay much attention to it, but it looked like a home made rig.
Would be possible and not too  difficult.  You could use a small air compressor driven by the pto to pressurize the tank, just like the hand pump models - don't forget a pressure regulator in this type of system, unless you want a big a badda BOOM!
wallfish
Where abouts in CT are you?
I have some sort of sprayer parts and frame with hoses and nozzles but it doesn't have the container tank or a pump. I don't know much about it as it came in on trade with some other stuff.  Certainly enough there to make what you want but I'd go with a readily available 12v pump.
Let me know if you're interested and I can get some pics.
elcamino/wheelhorse
You can purchase complete units or just the tank part from Northern. I purchased a complete unit that has a 12 V pump . Comes with lines to attach to battery . Has a long hose and a great nozzle . I just load the tank ( 16 gallon ) in the trailer hook up the lines and ride the tractor to where I want to spray. It was about 149.00 .
Dan.gerous
Pictures please 😁
elcamino/wheelhorse
@Dan.gerous I will try to get you some pictures tomorrow.
squonk
You must have some big honking bugs at your House! :bow-blue:
elcamino/wheelhorse
It is for Black Spot fungus . About 100 feet of red tips and other bushes it attacks.
squonk
The fungus is among us!
  • Haha 1
elcamino/wheelhorse
@Dan.gerous Attached are pictures of the sprayer and the trailer I haul it . It is a Model 99919 for Northern Tool , holds 16 gallons . Has an external filter which is removable .It has an on/off switch on the cable that hooks to the tractor battery. It has about 15 feet of sprayer hose. It has these plastic clip to hold the spray wand when not in use. They are junk and do not work. Has a nice large opening on the top for loading chemicals   and a drain on the low side on on end remove any left over chemicals.
Skipper
You can get small roller pumps for pto use if you like that over electric. However the electric work just fine, and not that much current draw. You could make a bracket for something like this on the back too. Would take some counterweight on the nose though :-)
More on that here:
Edited by Skipper
  • Heart 1
