sdotzel@yahoo.com 0 #1 Posted May 25, 2020 I have a 69 gt14 that was working fine and now my hydraulic lift is not working, can not raise my cutting deck. Goes forward and back no problem. Fluid is full, wondering what to check first Share this post Link to post Share on other sites
Lee1977 6,777 #2 Posted May 26, 2020 1 hour ago, sdotzel@yahoo.com said: I have a 69 gt14 that was working fine and now my hydraulic lift is not working, can not raise my cutting deck. Goes forward and back no problem. Fluid is full, wondering what to check first First thing I would check is all the mechanical connections between the cylinder and the deck. One of them may have come apart. Share this post Link to post Share on other sites
daveoman1966 3,762 #3 Posted May 26, 2020 Is the cylinder ram moving? If so, then lift linkage is likely the problem. Share this post Link to post Share on other sites
pfrederi 17,868 #4 Posted May 26, 2020 Linkage first. If it is OK then the implement relief valve spring next. Share this post Link to post Share on other sites
sdotzel@yahoo.com 0 #5 Posted May 27, 2020 11 hours ago, pfrederi said: Linkage first. If it is OK then the implement relief valve spring next. 11 hours ago, pfrederi said: Linkage first. If it is OK then the implement relief valve spring next. Cylinder ram does not move. All linkage is good. Is the implement relief valve spring in the lift control valve or the transmission Share this post Link to post Share on other sites
pfrederi 17,868 #6 Posted May 28, 2020 On 5/26/2020 at 9:06 PM, sdotzel@yahoo.com said: Cylinder ram does not move. All linkage is good. Is the implement relief valve spring in the lift control valve or the transmission It is located in the hydrogear pump head Download the service manual here. Share this post Link to post Share on other sites
