TSingleton
Belt tension on PTO/Mule Drive
TSingleton
Have a 416-8 with a newly acquired 42” SD deck. Just got it all setup and mowed for the first time today. Pretty pleased overall. PTO belt is new. Mowed about 30 mins total. How tight should the belt be? I know the handle on the mule drive is the adjustment. I set it decently snug before I started. When it is running does the belt still “dance” around some between mule drive and mower deck? I just don’t want to over tighten it. Thanks in advance!
moe1965
Mine dances around as well I wondered the same thing you are asking about. My opinion is if the mower is cutting and not leaving uncut grass behind its tight enough.  Maby someone has more info.
daveoman1966
The PTO belt for the 42 deck w/b # 102742...  103" x 0.5".  Midway of the PTO to Mule drive, the belt should deflect 1/2 - 3/4" ...
An aftermanrket belt used here MAY give issues just like using the NAPA belt on the engine to trans.  Get the OEM belt...
https://www.psep1.biz/arinet.asp?aribrand=TO#
Edited by daveoman1966
TSingleton
@daveoman1966 I got the correct size on this one lol. If I remember correctly it’s a Kevlar type belt? Napa let me down on the other belt though. Appreciate the help.
oldlineman
I adjust mine so that I can just, with two fingers squeeze the belt together midway between the mule and  and drive pulley. I use thumb and index finger. I know this can be subject too the strength of your hand, but how I do it.Bob
dcrage
I was able to stop my PTO to deck belt from ‘dancing’ by LOOSENING it a small amount. I do not have a good explanation, I assume it has something to do with harmonic resonance??
