Flat Thunder Channel
520-H Ignition Trigger - Replacement
Hello everyone!  I am going to replace the ignition trigger on my grandfather's 520.  Any tips, tricks or important things I should know before starting?  I already have the parts.  I just need to tear into it.
I didn't know Cummins owned Onan.
WHX??
Yeah for a few years now... they wanted a piece of Onan's genny action I think.
Change out is pretty straight forward. Quite a few threads on doing it here. Some may suggest taking a look at the governor as long as the flywheel is off.
here's a manual if you don't have one.
492-4006 Onan P216 P218 P220 P224 SM.pdfFetching info...
lynnmor
Onan started using a gasket like material under the trigger, if it doesn't have it, I would add it.  Some think it is to reduce heat transfer.
You may need an impact wrench to remove the flywheel bolt if the tractor was exposed to water too many times.  I only had one that was frozen like that, the threads fought all the way out.  Clean the bolt and crank threads and make sure the bolt threads in easily with your fingers, I had to run a tap in on the frozen one.
Watch how the flywheel key is installed.  Clean the crank and flywheel thoroughly using 600 grit paper or crocus cloth, torque to 55 lb. ft.
Thanks for all the information!  I wasn't overly worried, but sometimes getting others perspective is helpful / time saving.  I downloaded the manual for future reference too. 😁
I fixed it!  Check out the repair video if you are interested in replacing a ignition module (crank trigger) on a 20 HP Onan.  The video illustrates the symptoms it experiences in real life.  Hopefully it will help others diagnose problems on their 520 Wheelhorse.  Dad and I struggled to identify this problem.  We never made it a priority and the problems it experienced were similar to a fuel delivery issue.  I am happy to say she is back in action!!!  Go team Wheelhorse! :)   520 HP WheelHorse; Engine Repair
  • Like 5
tom2p
Nice job !
( commented in other thread )
Pappy 4430
Can you give me those part numbers please ? Can't read the trigger number.
Thank you very much
Edited by Pappy 4430
Thank you very much
166-0785 & 166-0767
Pappy 4430
  On 4/17/2021 at 4:06 PM, Flat Thunder Channel said:
166-0785 & 166-0767
Thank you very much sir !
I have same problem with my 520-8
You are welcome!  Happy wheel horsing! 👍
Shippey
I know this post is old but wanted to pile on and say this video was outstanding.  I used it to fix my 520H.  I'd like to add a couple of notes and hope Flat Thunder doesn't mind.  First, when I went to order the parts I saw a note suggesting to order the rotor first as this was most often the problem.  The rotor was about $35 and the igniter about $140 so I thought I'd take the suggestion.  Turns out they were right.  Just changing the rotor solved the problem.  FYI since it was a little laborious to take apart and I thought it would be more so to put it together, I ordered the igniter anyway.  As it turns out, there was a 2 week delay to ship it so I put it together with the rotor only and cancelled the igniter after the problem was solved.
Second, the fly wheel cover comes off, and more importantly, goes back on if you take the regulator off,  It's the piece FT struggled with a little getting the fly wheel cover off.  It's only a short 3/8" head bolt and if you can keep from bending the sheet metal taking the cover off, it's a lot easier putting it back on.
Thanks Flat Thunder.
lynnmor
Was your rotor black or a light gray like the one shown in the first post?  Usually the newer light gray ones had fewer problems.
No problem!  I glad it helped out on the repair process.  Thanks for watching 👍😁
Shippey
The old rotor and the new rotor were both light gray.  But there's an update.
Shippey
I need to update my post above.  Specifically, "when I went to order the parts I saw a note suggesting to order the rotor first as this was most often the problem.  The rotor was about $35 and the igniter about $140 so I thought I'd take the suggestion.  Turns out they were right.  Just changing the rotor solved the problem".  Turns out it didn't solve the problem.  I replaced the rotor only in early Oct 21, when it was still warmish, and the 520H ran as it should.  So I parked it and waited for the snow.  When I went to use it in the cold of Jan 22 the shutdown problem returned.  In fact it was worse since it would only run for about 5 minutes when previously it would run for almost 10 before it shut down.  I ordered the ignition control from Jack's Small Engines which cost $163 with shipping.  Worst part was it took a month to get it.  I put the ignition control in and have run it for about an hour in 15 degree weather and so far so good.  It's parked again and waiting for snow.
Handy Don
Thanks for adding the extra post.
Supporters are able to go back and edit their earlier posts for up to, I think, 30 days. After that, depending on importance, you can ask an Admin to make the change. Non-supporters can only edit their previous posts for, again I think, 48 hours.
  I wouldn't change one without the other simply because it's such a time intensive process.  Glad you got it fixed up!
  This was one of the most difficult faults that I had to diagnose on grandfather's tractor.  Cheers,
RonnieB2nd
What's the problem? Trouble starting?
Shippey
Started fine but would only run 4-10 minutes and shut down like I turned the key off.  Had to wait 45 minutes to restart.
lynnmor
Temporarily, run a jumper wire from the battery + to the coil + and see if the problem continues.  Of course only use the jumper while actually testing.
  • Similar Content
    • Donavon1
      By Donavon1
      Need some help deciding on a brand of engine to buy for my 1054. (Needs to be a diesel 10 hp+) I’m refining used motor oil/cooking oil for fuel for it. So it will have to have an option to run used oil and diesel
    • 2drxploder
      By 2drxploder
      looking for a tiller for my 520h as well as some wheel weights. also maybe some good chrome hubcaps
      located in charlotte nc area
    • MainelyWheelhorse
      By MainelyWheelhorse
      Hi All, I’m a member of the RedSquare Facebook group, some of you may have seen My tractor there. I have a 1992 312-8 with a 37 inch deck. It came with a house my brother bought, and was given to me. It needed work but just minor things. I mow my lawn with it, and I just bought a plow to push snow/dirt so it’s a working restoration. It was relatively well taken care of by the previous owners so it really just needed a refresh. Anyway see you around the site!
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
