r1jakecfd
Rim dimensions for 24x12-12 rear tires- 520H
r1jakecfd
Hi Guys,
I just bought some Carlisle Turfmaster 24x12-12 rear tires to replace the 23x8.50-12 tires I have on there now. I was wondering which rims I should buy to fit these bigger tires. The charts say an 8.50 width rim but should the offset stay the same or does it need to change? Any other dimensions I should be concerned about?
Thanks in advance.
Hope everyone is healthy and well!
John
Lee1977
i would suggest putting them on and checking the space between the tire and gas tank brackets. I have a 1989 520-H but it has 7" wheels I put 24 x 9.50 x 12 on mine . I have 1 1/4" clear on the right and 1 3/4" on the left looking at the rear with a 2 1/2" difference between tire and rim.  You have a 3 1/2" difference between  the tire and rim. I'm guessing you will have a 3/4" clear on the right and 1 1/4" on  he left. Other brands of rear wheels have deeper back set then Wheel Horse.
Edited by Lee1977
Achto
A 10" to 11" wide rim is usually recommended for 12" wide tires. The offset will have to remain the same as your current rims. ie - all of the width of the new rim should be gained towards the outside, the distance from the mounting plate to the inside of the rim should remain the same.
A picture of one of my tractors with 26x12-12's these rims are 11 1/2" wide.
littleredrider
Miler tire sells the pieces for 12x10 rims. I'll get pics later, but I put a set of 25x12x12s on 10" rims, fits perfect on the 520. I'd say with that size tire need a 10", but not all tires measure true to size.
lynnmor
Your 520H should have come with 23x10.50-12 tires, since you have smaller tires, maybe the wheels are not original as well.
r1jakecfd
And who said we’d never use math after high school???🤣
This is really helpful. Thank you for the info. Always helps to hear other people’s experiences.
I’ll be sure to post pics when they are on. I’m thinking of just ordering the 10”wide rims to give more traction(less rounding) and more stability for the FEL.
Cheers
  • Haha 1
r1jakecfd
I bought it from a guy with a WheelHorse Graveyard behind his house so yes, non-OEM is most likely the case.
Truth be told, it was a little scary there... Deep in rural Northern VT... Was like a scene from deliverance. I pretty much loaded up and got the hell out of there!😂
r1jakecfd
That horse looks like a beauty!
The way you explained it answered my question perfectly clearly. Thank you.
Let me know if this makes sense:
My current rim is 7” wide. If I get a 10” wide rim, I divide the 3” width difference by 2 to factor for center offset (1 1/2”) and add that to the current offset? That should give me about the same clearance as the current tires(except for bigger tire diameter), correct?
Thanks for sharing your knowledge!🙏😊
r1jakecfd
Thanks Littleredrider(cool handle!).
I’m going to call Miller Tire this AM. To see what they have.
Cheers
Achto
I usually measure from the back of the rim to the mounting plate. I try to keep this measurement the same on my new rim. This way the inside of tire never gets any closer to the tractor.
littleredrider
pics coming up!!!
littleredrider
hopefully this works. The muddy ones are the 25x12x12 on the 10" wide wheels. I think the backspace on these are 1 1/2" or around there. The next ones (semi clean) are 23x10.5x12 on stock 520 8.5" rims. Firestone 23 degree tires. The sidewall "lines up" with the wheel, so IMO, they are a perfect fit. Any wider a wheel will make the tire bow out too much, then risk damaging the wheel if you scrape a curb or whatever.
littleredrider
littleredrider
littleredrider
littleredrider
WHX??
Beauti is putting it lightly!
Those Firestones are boss :wicked: Little Red... some day I win the lotto or rob a bank.... :lol:
  • Haha 1
littleredrider
They weren't that expensive when I got them bout 2 years ago. It's sad, ATV and garden tractor tires are becoming as expensive as car tires...
Tractorhead
Yes they are.
lurking on fleebay for a Set Reartyres.
They ask here about 110 up to 320€ A set reartyres.
They call it also the black Gold...
r1jakecfd
That’s how I did it too. I did actually find a couple of great PDF links including a graphic worksheet to spec a wheel that makes it easy. Its from Wold Wheel, an OEM and custom wheel/rim manufacturer.
https://www.woldinc.com/useful_info
Happy Memorial Day!
RandyLittrell
Bought a couple of tractors down in Arkansas one time, told my Dad when we got there, they will never find the bodies if this goes south!!
Randy
r1jakecfd
Randy
Oh boy... It’s a whole different world out there. Can you picture the amount of Red Horses doing a “mounted” search if anything ever happened to you guys?😂
  • Haha 1
Tuneup
When we went to pick-up the son's '80 Kawi a few years ago, we were met with an open gate with flashing yellow lights on phone polls lights and a sign that said no law enforcement beyond this point. They were working out of trailers. Just good 'ole boys but it felt a little creepy...Woodstock GA.
So, wanting the same, it seems it's time to find a welder. Any task that requires a new tool is a very good thing around here. Thanks, all!
  • Similar Content
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Jon Paulsen
      By Jon Paulsen
      Inexpensive - Carlisle X Trac ATV Bias Tire - 16x6.50-8 Good quality (I expect) Should look nice with my large rear aggies
      I don't know how much these have been discounted, but I expect anything you find like this from a good brand will be 2X to 3X the price. $45 each at Amazon. This tire is discontinued.
      Rough measurement seems they are about 16" tall and the lugs are about 1/2" deep.
    • PWL216
      By PWL216
      Are there aftermarket front rims available for C Series tractors? I have a 120 and a 160 that need front rims… thx.
