Jereco1
jereco1
Jereco1
my rear discharge mower disengage while mowing. I can re engage the blades and start mowing and a short while mowing the blades will disengage again,  help!
Vinylguy
Welcome to the forum! :text-welcomeconfetti:
What tractor model is your deck on?
Jereco1
Wheel horse C165 8 Model 11-16k801
Jereco1
C165 8 model 11-16k801
Vinylguy
Most likely a mule drive adjustment but someone with way more knowledge than I will be along to give you better advice.
Ed Kennell
Try shortening the PTO engagement rod.  Pull the hairpin clip and turn the trunnion 1 turn Clockwise.
  • Like 4
SylvanLakeWH
:text-yeahthat:
Want to make sure the tension is correct on the belt from the front mule drive.
:text-yeahthat:
PTO engagement rod needs to throw far enough forward to stay engaged...
AND...
Good to see another Michigander!
Pullstart
953 nut
:WRS:                                           :text-yeahthat:     as you push the PTO lever forward it needs to go "over-center" to remain locked on.
jay bee
:text-welcomewave: @Jereco1  to :rs:  Another MIchigander.....Yea!!!
  • Similar Content
    • t_furl43
      By t_furl43
      A Wheelhorse C-165 8 speed, nice solid tractor everything works and operates as it should, all lights works(stack will be removed before sale)unknown hours it was only an option for the 165, but the 16hp single lung cast iron K series motor starts right up and runs strong. It will need new motor mounts. Transmission shifts smooth, package comes with plow w/optional down pressure bar if you choose instead of your trunnions chain, a set of tire chains, a set of Toro brand front wheel weights and a set of generic rear wheel weights, and lastly a full set of hub caps that are in decent shape they can be cleaned up, $1000 obo. Would like to sell as package but if the right buyer was interested in the right combo of stuff for the right amount of money we could work something out. Pickup only in Millersville PA 17551
