71_Bronco 1,072 #1 Posted May 13, 2020 (edited) On my 5060 transmission I'm rebuilding, I purchased a new brake band liner from our local RS member @rmaynard The brake drum is part number 3902. I have the one that came on the 5060 transmission, as well as the one from the 5053 that is currently in my Commando 8 (the 5060 is going to get swapped into the Commando 8). Is there a spec for the outside diameter I should need? Or do these drums not really wear with use? I dont mind putting new parts into this 5060 if needed, but I'm not sure how to tell if I need a new drum or not. Thanks! Edited May 13, 2020 by 71_Bronco Share this post Link to post Share on other sites
ebinmaine 80,264 #2 Posted May 13, 2020 As long as it's not rusted to perforation or the metal parts have been in contact with each other you should be fine. Share this post Link to post Share on other sites
stevasaurus 23,802 #3 Posted May 13, 2020 Right Eric...I have never seen any wear on the drum itself. 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #4 Posted May 13, 2020 3 hours ago, stevasaurus said: Right Eric...I have never seen any wear on the drum itself. Thanks. I wasnt sure if it was the friction material that wore, the brake drum that wore, or a combination of both. Kinda like the brakes on a car. I'll just clean up the ones I have and mount the better looking one. Share this post Link to post Share on other sites
ebinmaine 80,264 #5 Posted May 13, 2020 Just now, 71_Bronco said: Thanks. I wasnt sure if it was the friction material that wore, the brake drum that wore, or a combination of both. Kinda like the brakes on a car. I'll just clean up the ones I have and mount the better looking one. it probably is a combination of both pieces wearing to some extent just like on a larger vehicle. On drum brakes I've never gotten too concerned about a groove or two. Just clean up the drum of oil if there is any, and maybe scratch a light glaze on to the drum, at most. Even if the drum itself doesn't have a perfect surface there is a large amount of contact area and the shoe will seat in a little if it needs to. Share this post Link to post Share on other sites
