Johnpl 2 #1 Posted May 12, 2020 Just bought a Wheelhorse 314H. It uses a Kohler single cylinder M14S engine. Toro website parts diagrams and lists show just about every part, nut and bolt on the machine, including the filter for the hydrostatic transmission, but I can't find anything on Toro website about engine oil filter. Also can't find correct filter on websites of small engine parts vendors. Can anyone tell me what the correct filter is, whether sold by Kohler or other reputable company? Share this post Link to post Share on other sites
ebinmaine 70,810 #2 Posted May 12, 2020 From another crazy Mainah. All my horses are old so I don't have the information you looking for but somebody will be along soon I'm sure. Share this post Link to post Share on other sites
oldlineman 1,495 #3 Posted May 12, 2020 I have a 1990 312 H and a 1989 414-8 neither one has a engine oil filter. Non pressure oil lube. Share this post Link to post Share on other sites
Johnpl 2 #4 Posted May 12, 2020 oldlineman, If my tractor has the same setup, it would explain why there is no oil filter showing on the aprts diagrams. Share this post Link to post Share on other sites
Guest 88vic #5 Posted May 12, 2020 (edited) Kohler 12 050 01-s or 52 050 02-s pro filter Edited May 12, 2020 by 88vic Share this post Link to post Share on other sites
Guest 88vic #6 Posted May 12, 2020 Or you can use a Fram filter found at any auto parts store or Walmart PH3614. Share this post Link to post Share on other sites
ebinmaine 70,810 #7 Posted May 12, 2020 4 minutes ago, WHEELHORSEFAN*19 said: Or you can use a Fram filter found at any auto parts store or Walmart PH3614. Try to get Wix if possible. Far superior quality... IMHO... 1 Share this post Link to post Share on other sites
Guest 88vic #8 Posted May 12, 2020 Napa 1348 or Wix 51348 Share this post Link to post Share on other sites
Guest 88vic #9 Posted May 12, 2020 I have never seen a Magnum single cylinder with an oil filter, maybe a twin magnum. Maybe there was a factory option for a remote oil filter ? It would be neat to see a picture of said setup. Share this post Link to post Share on other sites
Guest 88vic #10 Posted May 12, 2020 My 314-8 has a kohler command series and it does have an oil filter. Share this post Link to post Share on other sites
pfrederi 18,345 #11 Posted May 12, 2020 What is the spec number of your engine....Magnum singles were splash lubed no filters... Magnum twins, filters were an option that WH did not use. Share this post Link to post Share on other sites
WHX?? 50,782 #12 Posted May 12, 2020 1 hour ago, WHEELHORSEFAN*19 said: My 314-8 has a kohler command series and it does have an oil filter. We gonna need to see pics of that horsefan...maybe he has got some sort of replacement motor ??? Johnpl Share this post Link to post Share on other sites
Johnpl 2 #13 Posted May 13, 2020 19 hours ago, WHEELHORSEFAN*19 said: Kohler 12 050 01-s or 52 050 02-s pro filter 19 hours ago, WHEELHORSEFAN*19 said: Kohler 12 050 01-s or 52 050 02-s pro filter Thank you for all the replies. The information I have received is enough to get me headed in the right direction. Share this post Link to post Share on other sites
clueless 3,114 #14 Posted May 14, 2020 The reason you can't find an oil filter is because the Kohler M14 doesn't use one. The filters posted here or for Kohler Pro 14. Share this post Link to post Share on other sites
Johnpl 2 #15 Posted May 14, 2020 I'm getting something of an education into different types of Kohler engines in the different models of Wheel Horse Garden tractors. I appreciate the help. 2 Share this post Link to post Share on other sites
