olddude
Figuring blade speed
lynnmor
Adjust the friction on the throttle by putting a screw thru it with a locknut.
Adjust the friction on the motion control by adjusting the nut atop the hydro unit, under the seat, like it says in the manual.    First clean any grease from the friction washer and never lube it.
Sharpen the blades at the original angle and keep them sharp.
olddude
Found a deck but it's a 78361 and the one on mine is a 78360. I think I read that the 78361 superceeded the 78360 so will it work on my 520H?
gwest_ca
79360 up to 1998
79361 1998 - on.
Yes it will fit.
Garry
olddude
Well I found a deck on Craigslist and went and picked it up yesterday. Got it back home and couldn't help but to put it on and try it out. I got it switched over and and could tell before I finished the hook up that something was different. That deck went on like a snap everything lined up and things went together so easy I thought I had left something out. It took longer for me to remove the old deck than it did to hook up the new one. The old deck always was a pain to remove and put back on. I looked at both of them and couldn't really see anything different but there has to be something out of wack with that old deck. I'm going to look at it closer today to see if I can spot something wrong.
The new deck came off of an older tractor but it was never used much. There was an old set of belts on the deck that the guy said were the original belts that came on the tractor. He bought the tractor new with a rototiller attachment on it and that was mostly what he used that machine for. He got tired of  stumbling over the deck everytime he went into his shed so he decided to sell it. He wanted $475.00 but I went over there with $400.00 and came home with it.
As soon as I hit the PTO lever and the blades started turning I knew this was a new ball game. The other deck has always made a lot of noise even after I replaced the bearings in the spindles along with a bunch of other things. This one is quiet all you hear is that wonderful harmonic balance between blades wirling and the soothing sound of that 20 HP Onan singing. OH, and it cuts like a charm. I cut a few weeds first but couldn't help but to give it a try on a section of Zoysia that is well established and all I can say is that I'm well satisfied and it's the best I've ever seen that grass look after it was newly cut.
I can't be too hard on that old deck it had 1500 hard hours on it and has cut probably a million miles worth of grass under it's belt and I'll have to say it was still cutting the same as it did when it was new.
olddude
17 minutes ago, gwest_ca said:
79360 up to 1998
79361 1998 - on.
Yes it will fit.
Garry
That's strange because the guy said it came off an older tractor and mine is a 95 I think. Also he said it came off a 300 series tractor.
Edited by olddude
added content
r1jakecfd
This may sound silly and hope I’m not insulting you but are you running the belt on the inner(larger diameter) PTO pulley groove?
just a thought as that can have a big effect on blade(or other attachment) speed.
Good luck🙏
Skipper
Not trying to tease here either, but even at low engine speed you should be able to cut. Something must be wrong. Are you sure the blades aren't on the wrong way, or the belt twisted so it turns backwards.?
I have a few passes where the wife don't want clippings in the flowers, and I cut that a idle, or just a tad above. Works fine. and my grass is the super fine straw type. I cut at app. 2" hight.
There must be something way wrong for it to cut that bad. I once changed blades in a hurry, and got one on wrong side up. That looked way less than good. Kind of like you describe. Have also seen severely warped decks cut bad.
If you post some pics of your old deck, both sides, I think the guys here will spot if something is out of wack. ;-)
olddude
Good luck🙏
Not silly at all but no It's setup and running in the right groove. I don't know if you read the post above about the new deck I found but that fixed the cutting problem. It cuts like a charm now. Thanks.....
r1jakecfd
So glad it’s fixed and running smoothly. Sorry, there were a bunch of replies so I skimmed really quickly.
I have the 48” side discharge on my 520h. When I first bought it, it cut terribly until I adjusted the mower blade level(front to rear) adjustment. It made a huge difference when I followed that procedure and dialed it in.
I will say, I really miss my old 42” rear discharge deck. It cut beautifully and allowed me to pull a sweeper to collect the clippings at the same time. I have no bagger for the SD which makes it a 2 step process. Oh well, I guess it means more quality time on my “Horse”👍😊
Cheers
olddude
Not trying to tease here either and don't take this personal but think about this.........I've been cutting grass with this tractor for well over 20 years and in all that time it has cut grass the same. What would you think the chances would be for me to put the blades on backwards or get the belts twisted that many times over the course of that time period? No the blades are not backwards And I'm not sure what you really mean by twisted belts but no the blades are turning the right way. As I said in an earlier post I change the blades every year and I do keep them sharp I also put on a new set or belts needed or not every year. I have always done it that way but I do keep a couple used belts laying around in case something gets hung up somewhere and breaks one along the way. so I can get by until I get a new one.
I never really worried about it much until I finally started plugging my yard with Zoysia plugs and it finally got established. For 25 years all I could get to grow was weeds even after hiring a professional landscape company for 4 years to maintain the yard. I finally fired those guys and all their excuses because I still had a yard full of weeds. The way the mower cut then it really didn't matter because weeds are weeds and no matter if I cut the yard 3 times a week it always looked the same.......the morning after there were seed heads sticking up all over the place.
I finally semi retired and then I had the time to try once again to get some grass to go. The first year I put down weed killer on the grass that went out from the house about the 1st 40 feet. I killed the summer grass and weeds and went on into the winter with the fall grasses and killed that too. The next spring I went out with the troy built tiller and chopped up the whole yard and waited until the new seeds started to sprout and I killed them too. Some more came up and I killed them too and then I ordered 3 or 4 thousand zoysia grass plugs, I couldn't afford to do the whole thing in sod. I started at the house and these plugs got me out about 20 feet all the way around the house. That year I kept up the weed killing on the part I hadn't planted. By next spring the newly planted plugs had almost filled in the area completely and had started sending runners out from the edge a foot or so and I ordered 3 thousand more and this brought me out to about the 40 foot mark. I expanded the kill zone another 15 feet or so and have been doing that since moving out more as the Zoysia expanded outward.
One thing about this type grass is once it gets to going it wants to go and sometimes it will go where you really don't want it to. Then it becomes a weed to most people but not me. I would gently dig it up and I started little patches in different parts of the yard where the weeds once ruled and with only 4 or 5 small pieces here and there after a couple years I have 5 or 6 foot spots in the other parts of my yard that are nice and green and is still expanding. At first I was cutting it with a small 32" cut self propelled mower with a bagger and that was okay when I just had a small amount to cut but soon I would have to stop every lap to empty the bag and that was such a pain.
I really can't  afford to go out and buy a 7 or 8 thousand dollar mower at this time and it was then that I started trying to figure out how to get this one to cut some where near well enough until I can get something else. Now that I have put that new/old Craigs list deck on it the thing cuts much better. I'll go along with you on the,  there has got to be something wrong with that deck though what that is, is hard to say. I had it back at the dealers place several times and they said everything was okay.
  • Confused 1
olddude
Cheers
Nothing better than making laps on the 520H and a ice cold Bud Lite riding along as a co pilot.:auto-driving:
Goofey
Pics would help a lot if you want that old deck running again. As has been said. There sure is something all wrong with it the way it acts up. Now from what I know about decks, there are only a few things to go wrong. Only a very few is to blame on the deck it self. I apologize, but I doubt I'm the only one to think operator error of some sort. Despite all those years of mowing people still sometimes makes a mess of things. And I doubt this has anything to do with what kind of grass you have either.  Again. Pics would help a lot.
IMO that is.
lynnmor
I had a friend with the green & yellow addiction, he worked on all his toys most of his life.  One day I stopped by and saw his usual well manicured lawn looking awful, and he couldn't figure out the problem.  Yep, one was upside down.
olddude
IMO that is.
I'm not really worried about that old deck anymore. I'll just use it in the winter months keeping the woods and rough stuff in shape. Oh yeah.....I know anybody can sometimes have an awh crap moment and make a mistake or two. I have had them a time or two...:scratchead: I guess what I'm saying is putting on a blade upside down a time or two.....yeah maybe, but for that long and that many blade changes.....I don't think so. I don't think that even I could overlook some like that for that long of time. And you would think that if that was the case that the dealer would have caught something like that by at least the third trip that I took it back in to get it looked at.
olddude
I'll have to admit that one time right after those Ninja blades first came out I bought a set to try out. I took them out of the box and laid them out on the floor in the upright position but when I was laying on the floor looking up I put everyone of them on upside down, some kind of brain fart I guess but it didn't take too long to figure out that something was terribly wrong.:jaw: I'm glad noone was around when that happened.;)
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
