olddude
Figuring blade speed
olddude
My 520H has never cut grass really well. It seems this deck is more like a bush hog than a finish mower. It doesn't seem to mind if the grass or weeds are really tall it will mow them down but that's about it. I have a Zoysia lawn that I like to cut at 3" but when I do it never looks neat. This grass is just around my house about 40' or so all around. The rest of our grass I have to cut is a mixture of grasses but now mostly weeds. The zoysia is slowly spreading out into these areas and does a pretty good job of controlling some of the weeds once it gets established.
When I cut the Zoysia I try to keep the RPM's up and I have been reducing my ground speed but it still doesn't leave the grass like I would like. It sort of looks like all three blades leave a different pattern if that makes any sense. I put on a new set of blades and belts each spring after the second or so cut once all the winter leftovers are all cleaned up but even with new blades it's about the same. It's a 48" deck and I'm thinking that the 48" deck would be the max for the 520. I have a smaller WH with a 42" deck that would cut the grass much cleaner but that old deck is past worn out and I just use that one for a pull tractor.
I'm wondering what the blade tip speed is for the 520 H with a 48" deck. Is there a chart somewhere that will speak to this?
oilwell1415
Never seen a chart, but it's not hard to figure.  It's just engine speed in rpm x (sum of drive pulley diameters/sum of driven pulley diameters) x blade diameter in inches x 3.14.  That will give you inches per minute.  For feet/second divide by 720.
oldlineman
That 520 will handle a 60" deck so 48" is no problem. Have you ever checked your tractor RPM's maybe not turning 3600 RPM.
gwest_ca
One manual I have states the maximum allowed blade tip speed is 19,200 feet per minute. This one says 19,000.
Garry
Ed Kennell
Is the deck adjusted properly?    The front edge should be 1/8-1/4 " lower than the back.
Is the deck belt and tensioner  and spring clean and working properly so the two outside blades turning at same speed as the center blade?
lynnmor
When you say "I try to keep the RPM's up" are you running the engine at full speed?  Is the throttle drifting down as you mow?  Are the blades sharpened at the proper angle with the edge very sharp.  Rotate blades to see if the tips match each other to see if the deck or blades are bent.
littleredrider
My 520-8 has a 60" deck and even with the wings busted off it still cuts grass beautifully. Even after I used it has a brush hog. Make sure engine is operating at correct RPMs, and as others mentioned the belts are tight and in spec. Should cut like a dream.
oliver2-44
I suspect Zoysia being a fine blade grass makes it a bit more of a challenge to get a beautiful cut.
My previous employers main office had a lot of water efficient demonstration landscaping which included Zosia grass.
Reel Mowers are almost never seen in Texas except on golf courses, but the lawn contractor cut the Zosia with a reel mower.
olddude
This tractor doesn't have a tach per say, it has a power percent gauge and it will run at the max hp according to the gauge.
olddude
I have been over this thing a million times and everything seems to be adjusted. I rebuilt this deck a couple years ago and when I did nothing really changed much it cut about the same as before. I had some problems getting the right parts for some of the things I needed. Looked up the parts then ordered them and some stuff came back that were different than what I had on my deck. They were marked with the same part number but were different. The parts place just said you ordered the parts and they sent what you ordered. I ordered from a couple different places before I got the right parts. I don't know why Wheel Horse/ Toro has to be so difficult.
When I rebuilt the deck I never did get the right Idler pulleys after about 5 try's so the old ones are still on there. I just got tired of messing with it. I'm thinking I would like to replace all the pulleys and probably would if I thought I could get the right ones. It seems that you should be able to give the parts place the deck model number and they would be able to get the right parts for it. Maybe one day.....
  • Sad 1
olddude
When I'm just cutting my weeds I usually don't run it wide open. This thing has never liked to stay wide open it seems the governor likes it to stay just a little off wide open and if I want to keep it wide open I have to hold the throttle lever to keep it that way. Tried new cable and it still does the same thing. When I'm cutting my good grass I do hold the lever to keep her reved but it still cuts the same. I just put on a new set of blades and belts and no difference.
olddude
Yes Zoysia can be a pain to cut but I had a friends Dixie Chopper over here to do service on and that machine cut it just fine even with not so sharp blades. Like I said I've had this tractor since 1997 and it has never cut grass the way I thought it should. Don't get me wrong I love this tractor it's been a great machine for most of what I wan't it to do. My little 416-8 with the 42" deck cut grass so smooth and nice it's a shame this one won't. I have a feeling there was something wrong with this deck all along but if there is I can't see what it is. The dealer I bought it from told me that was just the way they cut and even told me they weren't considered a finish mower. Of course that was after I had bought it.:huh:
oilwell1415
The engine always needs to be wide open when you are mowing.  That may not fix your issue, but it's definitely not helping things.
lynnmor
There are many posts on here about the throttle moving down.  There is a pivot point on the throttle lever behind the dash, to tighten that joint, some smash the rivet, others drill it out and put a bolt thru, I use a small alloy screw with a lock nut.
I sharpen new blades, rarely are they really sharp.  Did you compare the blade tips to see if they line up when they tips are next to each other?
Run the engine at full speed when mowing, see your owners manual.
Did you level the deck with the front being about 1/8" lower than the rear?   I don't go to the maximum 1/4" so that the cut is a bit more even.
Are you cutting too low?  These decks often need to be run as high as possible.
My 42" rear discharge is no better than my 48"  and 60" side discharge decks.
oilwell1415
Funny you mention that.  I've noticed the same thing with new blades the last several years.  Not only are they not sharp, but they are not made out of very good steel and the edges don't last very well.  I usually do a rough sharpen, then harden the leading edge of the blade, then do a final good sharpening and I have had much better performance and longevity from the blades.
gwest_ca
The problem of getting the correct parts is likely due to the fact they share a parts list with a similar deck. Most times the 42" and 48" are shared but the online information does not distinguish between the two or identify what fits what. If you follow the item numbers in the list down near the bottom they are repeated with different part numbers. Blades are one item that is different so if you know the correct blade numbers the parts with them are for that size of deck.
If you can find an original parts list the parts are correctly identified.
Click on the picture. Just a guess on the model and vintage.
Garry
tom2p
I use Toro / Wheel Horse OEM blades
I've read there are other quality blades available - but have not tried them
just based on appearance - the quality of the OEM blades I purchased years ago (early 90's) is better than the quality of OEM blades purchased during the past few years
the older blades have a rounded edge where the blade is not sharpened (instead of square / unfinished)  -- the sharpened edge is cleaner and more uniform -- and the blade is just slightly thicker ... small amount - half a mil ?
posdible the earlier / older OEM blades were made in the USA - and the more recent / current OEM blades are made ... who knows where ...
Edited by tom2p
tom2p
i cut with 42 RD - 42 SD - 48 SD
( currently mounted on three different tractors )
the 42 RD ranks the lowest in yard appearance after a cut - primarily because the RD deck does not have the rear rollers (that can provide a better appearance)
I rarely run at full throttle - but yard still has good appearance after a cut ... guess there is a benefit to a yard full of weeds ( 'farm grass' )
Edited by tom2p
tom2p
for RD (rear discharge) deck - I set the front higher than the rear
the clippings are better dispersed - and less clumping when cutting tall grass
this after years (and years) of observation / cutting with RD deck ... going back to mid-70's with a 704 (with 32" RD ?) and then 312-8 with a 42" RD ...
only used SD decks for around 20 years ... started in early 2000's ...
lynnmor
It actually says that in the owners manual.
Edited by lynnmor
tom2p
  On 5/13/2020 at 1:23 PM, lynnmor said:
It actually say that in the owners manual.
yes - thank you - I believe Garry also mentioned that
years ago I was told to run front lower - but possible they did not realize I was using a RD deck at the time or did not realize can be different for RD and SD
I also installed a short extension on the 42" RD deck to reduce clippings on rear of tractor ( and better quality idler pulley recommended by Garry )
Edited by tom2p
olddude
Thanks.....like I said I do run wide open when cutting my zoysia......the weeds I don't care about.
olddude
Yeah, I have mashed that rivet and it seems to do ok for awhile but it will loosen up again before the season is over. The motion lever likes to do it also and I have to hold the lever forward when I want to travel at a fast pace. I thought about putting a foot throttle on the ol girl but never have.
Yes sir....I have checked all those adjustments and all are adjusted according to the manual. And no like I said I like to cut my zoysia at 3" which is about all the adjustment I can get out of this deck. That is unless I run with the deck in travel position.
olddude
I use Toro blades and they always seem to be fairly sharp. I always heard that you shouldn't put a fine edge on mower blades for reasons that they seem to dull so fast. I usually put an edge on them about once a month in summer or sooner if I run over something you probably shouldn't chop up.;)
As I said before I cut as high as the deck will allow which is around 3".
olddude
I've been looking around for another deck but the ones I have seen have all been fairly well used up and they want too much for what they are. I found one that was in real good shape and went by to pick it up but someone got there just before I did and snapped it up. I still think this deck must have been a late Friday or a very early Monday morning assembly but who knows?? It's probably the reason I have it and not the guy who originally bought it. The old guy bought it and bought it back to the store before he ran the first tank of gas through it and wanted his money back. The dealer never said what the guy didn't like but he offered it to me at a price I couldn't turn down.
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
