meadowfield
C-121 restoration - proper back from the dead stuff...
WHX??
What the heck holds that hood on ...looks as bad as the motor tin!
Goldnboy
The tool you used to remove  the flywheel  is what I recommend  on removing  the engine pulley by threading 2 bolts in the 4 possible  holes. With my luck the bolts would have broken the groove on the pulley the way you accomplished  the task!
meadowfield
I didn't have any 1/4-20 bolts to hand - so knew the risks...  Might put some on the shopping list for next time (and some longer bolts for the flywheel - they only went in a few threads)
meadowfield
Thats a task for another day....  lessons in welding rust :D
  • Like 3
  • Haha 1
Pullstart
Seeing what you guys have built out of much less, this’ll be another dandy in no time!
ebinmaine
:popcorn:
This could get good. I'll be here following.
@meadowfield
I can't download those videos onto my phone. Do you have a YouTube channel or link?
PeacemakerJack
:text-yeahthat: this will be a fun one to watch for sure!
953 nut
:text-coolphotos:           I guess we in the USA are a bit spoiled, too many good parts available to replace rusted out items.
meadowfield
  On 5/12/2020 at 9:54 AM, ebinmaine said:
:popcorn:
@meadowfield
added youtube :)
  • Thanks 1
Stormin
  On 5/11/2020 at 12:46 PM, meadowfield said:
I can beat that, Tyke. :DP1030158.JPG.91f4801e0806cbe3ac77948c4d8e6fd7.JPGP1030159.JPG.1d71cb5d42e1a7bf5a9632769d16265a.JPG
  • Haha 2
meadowfield
  On 5/12/2020 at 11:47 AM, Stormin said:
looks like a case of poor maintenance Norm... :D
Stormin
Nowt to do with me. C-125 I was getting up and running for a mate.:P
Edited by Stormin
meadowfield
todays update...
Managed to remove the seized hitch pin with a lot of heat and a big hammer - easier than drilling, but a lot of heat needed. Had to grind end where it was badly peened before knocking through.
before dropping transmission.
RH key was rusted solid - so more heat and a big punch, pieces shattered off!
four oil seals ordered and ready to split...
tempted to put a diff lock in this one - but I think time is against me at the moment. Despite being on lock down for 8 weeks :o
  • Like 6
  • Excellent 2
ebinmaine
  On 5/13/2020 at 9:03 AM, meadowfield said:
diff lock
How would you go about that?
meadowfield
there.s a build thread somewhere from 2014
  • Excellent 4
Pullstart
Woah woah woah!  That’s amazing!  What about the gear shift, or did this become just a differential case driven by the brake shaft?
meadowfield
todays exciting update :D
dropped the oil... well some of it.
image.png.5311a53cbebfa1ee1ee2f701e32d121d.pngimage.png.2e53bef2fced69cbc8d524d653ac8322.png
turns out it was mainly water, makes sense knowing how rusty the axles are and how much oil has leaked. Probably each time there was a hard frost water was being pushed out.
I've seen worse though, just needs a good clean. Axle seals arrived today, waiting for brake and input seals. Bearings all good though!
  • Like 5
  • Excellent 2
ebinmaine
  On 5/14/2020 at 9:28 AM, meadowfield said:
clean
Will you do a diesel or k1 flush or do you have a different method?
meadowfield
full strip and clean with gasoline!
  • Like 4
  • Excellent 2
meadowfield
Today’s update... all back together!
however having rebuilt a few and done extensive mods - even an 'expert' can get it wrong!
This this has been 'assembled' about seven times.
1. put main shaft in, both forks, forgot both sliding gears - so shift forks back out every time  (remember those fiddly bearings and the lock pin - yeah it falls into the bottom every time)
2. put main shaft and sliding gears in, couldn't get top sliding shaft in - couldn't see why
3. as above, but with shaft in - tried to put cluster gear shaft in - wouldn't go - pulled apart - shift forks out again.
4. put all gears in but then noticed 2/3 gear =s were swapped, no chance of cluster gear going in.
5. all gears in...  phew...  whats this washer?????
6. added small shim on input shaft - basically back to square one as after putting the high/low gears in, this should go next, before the main input shaft.
7. success :D
Maybe the manual might have helped - I did look at Steves videos yesterday, but I can see he suffers the same challenges - he does a good job of not cussing - I swore at those shift fork ball bearings a lot!!!
....tried all gears and made sure both housings slid together with a fresh gasket, axle seals and input shaft seal are done, waiting for brake shaft seal.
and more goodies arrived - new plug lead, air cleaner, fuel hose, rubber bung for fuel tank and the input shaft seal.
Edited by meadowfield
  • Like 7
Stormin
  Comes with age. :hide:
meadowfield
Today’s update... a full day of sanding and wire wheeling...
hopefully get some paint on tomorrow :)
  • Like 4
  • Excellent 1
  • Thanks 1
  • Similar Content
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • Baxtercr
      By Baxtercr
      Great condition C-121 for sale.   if any ones interested lets dm.    I'm based in North Yorkshire near Harrogate
    • Christof421
      By Christof421
      Hello, I recently purchased a single stage snowblower attachment for my C-121.  Currently going through my first storm with it.   Made some passes down the driveway and blower was blowing a bit of snow backwards under the tractor.   Snow is very fine and light snow.   Wondering if anyone else has experienced this or has suggestions on remidies.
    • ohiofarmer
      By ohiofarmer
      I found a standout looking C-121 . i found it on FBmarketplace, but those guys had it blocked for replying to the owner.  Ask price was only 220 and after i took the chance with screwing up my life on the computer, Facebook would not let me talk to the owner because it was too new. what FB wants is for you to hang out for a while and post.  My buddy jay was corrupted by me to get into old Honda motorcycles, so I had him do the contact and used me as an additional phone number.
         The owner texted me last night with permission to call him. he got an offer to buy while i was enroute to look, and since i texted him i was on the road, he waited for me. It is a one owner,bought for a project with the second owner deciding that the project might take longer than hoped. it's an eight speed that is putting a fine mist of oil inside the hood, so at least a head gasket or possibly a ring job, but it runs and is all there with a 38"' RD deck in great shape. No piccs yet as we are picking it up later this week. Gave him the money and he gave me a bill of sale. Farmer to farmer is why we came to that agreement
      It came up in conversation that we are both farmers, and it does make a difference that we would rather sell to each other than having random ppl from town casing our places for gas tanks to steal from and stuff like that.. Anyway, Jay needs to get away from green/yellow.
    • WH Believer
      By WH Believer
      I have wanted a good garden tractor for what seems like forever. Having moved into 1.24 acre yard I finally have a decent excuse. I have found a C-121 nearby on CL and they are asking $350. They claim it runs and cuts well while the pics seem to show a machine in decent shape. Having an abundance of zeal but minimum knowledge I come to the pros. I was wondering if a tractor this old was would likely leave me in the lurch but seeing the many machines you post on here still working after 50+ years speaks for itself! What should I look for if i get a chance to check it out? What in your minds would prevent the purchase? Bear in mind that while I would love to do a full restoration I don't have the time or resources for it now. I need to be able to get working with minimal wrench time. Does the support structure exist to find parts if something breaks?
           I have always been drawn to older machines (cars, motorcycles, anything that was built to last) and have fallen in love with the look and legacy of the Wheel Horse. Help me avoid an ignorant purchase that would spoil the fun.  Thanks
      Here's the CL link if it helps (don't scoop me now):
