johnnymag3 2,633 #1 Posted May 8, 2020 Looking to paint or treat my 310 and 312 stock mufflers black. Any ideas or suggestions....maybe something you guys have done or used and the results were good? Thanks everyone John Share this post Link to post Share on other sites
ebinmaine 75,748 #2 Posted May 8, 2020 BBQ paint... Good idea to follow the curing directions that will be on the can. 1 Share this post Link to post Share on other sites
peter lena 9,556 #3 Posted May 8, 2020 i use gas grill paint , often rated over 1 k for heat areas , i like the semi flat finish , never had a peel off or any issue with it . pete 1 Share this post Link to post Share on other sites
squonk 44,860 #4 Posted May 8, 2020 VHT High heat header paint available in several colors. https://www.vhtpaint.com/high-heat/vht-flameproof-coating 2 Share this post Link to post Share on other sites
lynnmor 8,254 #5 Posted May 8, 2020 I've had good luck with Rust-oleum High Heat Paint. 1 Share this post Link to post Share on other sites
lynnmor 8,254 #6 Posted May 8, 2020 Yes, I used the black and did multiple light coats. If you can glass bead all the rust off, you will get the best results. 1 Share this post Link to post Share on other sites
Stormin 9,986 #7 Posted May 8, 2020 BBQ paint or stove paint. Used both. 1 Share this post Link to post Share on other sites
WHNJ701 4,167 #8 Posted May 8, 2020 as others said, bbq flat black spray paint holds up just fine on the mufflers I have 1 Share this post Link to post Share on other sites
Bill D 2,442 #9 Posted May 8, 2020 I did my 312 with BBQ grill paint and it had held up well. Bill 1 Share this post Link to post Share on other sites
johnnymag3 2,633 #10 Posted May 8, 2020 (edited) 13 minutes ago, Bill D said: I did my 312 with BBQ grill paint and it had held up well. Bill Did it last very long, and did you use spray? POR 15 makes a high heat paint, but its super expensive. Brush application only John Edited May 8, 2020 by johnnymag3 Share this post Link to post Share on other sites
doc724 925 #11 Posted May 9, 2020 I used VHT. You have to cure it between coats. I used my BBQ grill as the curing "oven" 1 Share this post Link to post Share on other sites
Bill D 2,442 #12 Posted May 9, 2020 I did my 312 with BBQ grill paint and it had held up well. Bill Its a spray paint and it's held up well. If you can glass bead the muffler before painting that would be best. Bill Share this post Link to post Share on other sites
