chrisnjake9 0 #1 Posted May 7, 2020 hello i am new to the forum but i have looked at a few threads i am looking to by pass all electrical switches on my older 417-8 i tried running power to the coil no luck Share this post Link to post Share on other sites
lynnmor 8,864 #2 Posted May 7, 2020 There is a demystification guide in the manuals section that should help you. Just throwing new wires at it won’t help if the basic troubleshooting isn’t done. Share this post Link to post Share on other sites
WHX?? 57,105 #3 Posted May 7, 2020 Wiring on a 400 series is somewhat complicated so a wiring diagram is a must. If not we can get you one or check the manuals section. Need a little more info here, does it crank over? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,298 #4 Posted May 7, 2020 Working on this one now. What is not happening? Garry Share this post Link to post Share on other sites
chrisnjake9 0 #5 Posted May 7, 2020 it was quit rotted out in the battery box so i i clipped some wires thinking i could put a switch in to jump power to the coil well that didnt work it dose not turn over un less i cross the solonoid but still no spark Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,298 #6 Posted May 7, 2020 There are 2 pto switches and they are identical. One powers the starter circuit and the other powers the ignition when the pto is OFF. With the pto ON the seat switch powers the ignition. Here are the wire locations in the switches. Work on getting the key to make the starter work. When you get that see if you are getting voltage to the (+) coil terminal while cranking. It is not complicated when you disregard the wires going to the idiot lights. They have no affect on the operation of the tractor. They are just a monitoring system. Garry 1 Share this post Link to post Share on other sites
chrisnjake9 0 #7 Posted May 7, 2020 those were rotted off flopping around in the box i cut them out Share this post Link to post Share on other sites
chrisnjake9 0 #8 Posted May 7, 2020 i got it started and ran it for about 15 minutes now i have to rewire it minus all the safety switches . it appears it is not charging though i checked the wires coming from behind the fly wheel and none have power i pulled the fly wheel off and the magnets are all on the stator iv never seen that Share this post Link to post Share on other sites
chrisnjake9 0 #9 Posted May 7, 2020 it looks like the magnets should be attached to the flywheel their not they are on the stator any ideas Share this post Link to post Share on other sites
BOB ELLISON 2,983 #10 Posted May 8, 2020 Pictures will tell everything. Welcome to Redsquare Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,298 #11 Posted May 8, 2020 The complete file is finished. Garry Share this post Link to post Share on other sites
chrisnjake9 0 #12 Posted May 8, 2020 thank you i need to glue my magnets back on my fly wheel and i need a new pto clutch Share this post Link to post Share on other sites
oliver2-44 11,580 #13 Posted May 8, 2020 Can some one chime in here regarding gluing the magnets back on. am I thinking correctly that he needs to make sure he has the magnets arranged in North/South order, i.e. NS NS NS Share this post Link to post Share on other sites
953 nut 66,937 #14 Posted May 8, 2020 8 hours ago, oliver2-44 said: Can some one chime in here regarding gluing the magnets back on. am I thinking correctly that he needs to make sure he has the magnets arranged in North/South order, i.e. NS NS NS This thread should be helpful. Share this post Link to post Share on other sites
chrisnjake9 0 #15 Posted May 8, 2020 can any one tell me if a 16 hp fly wheel will fit my 417-8 Share this post Link to post Share on other sites
chrisnjake9 0 #16 Posted May 10, 2020 so can i buy magnets for my fly wheel one is broke Share this post Link to post Share on other sites
953 nut 66,937 #17 Posted May 10, 2020 Call Lincoln at A-Z Tractor, he can probably fix you up. https://a-ztractor.com/ Share this post Link to post Share on other sites
chrisnjake9 0 #18 Posted May 11, 2020 thanks nut i will try him tomorrow Share this post Link to post Share on other sites
chrisnjake9 0 #19 Posted May 13, 2020 cant i stack the magnets that will attract to each other in the u position there should be three each then glue them in alternating one from one stack then one from the other Share this post Link to post Share on other sites
