Edwin79 1 #1 Posted May 5, 2020 i was plowing with my electro 12 its a fully hydraulic model and i heard a pop and saw hydraulic fluid. its coming from dead center of the rear i dont want to kill her she has been great to me is this possably a rebuild thing or i am screwed thing i am new to the wheel horses this is my first one and i do not want her to die any help or guidlines woudl be helpful . 1 Share this post Link to post Share on other sites
lynnmor 9,050 #2 Posted May 5, 2020 A photo would help. You should describe the leak better, is it at the top center or at the back end? Share this post Link to post Share on other sites
stevasaurus 23,857 #3 Posted May 5, 2020 Welcome to Red Square. Anything you can tell us will help...pictures for sure...we do have the members to help you either fix it, or re-build. Do you have the model number or year of the horse?? Share this post Link to post Share on other sites
pfrederi 21,216 #4 Posted May 5, 2020 There is a hose from the back of the hydro pump that goes to the implement lift valve. Did it fail??? Share this post Link to post Share on other sites
Edwin79 1 #5 Posted May 9, 2020 (edited) ok sorry i didnt not make it clear. It poped from the bottom center of the trans. It is an electro 12 full hydrolic model its a 1969 with hydrolic deck lift also. it currently has a 16 horse and runs beauty. everything was fine before the pop lost all hydro fluid. no the implement lift valve was not an issue it is dead center of the bottom of the trans I will post pics soon Edited May 9, 2020 by Edwin79 Share this post Link to post Share on other sites
pfrederi 21,216 #6 Posted May 9, 2020 The pop was probably a differential bolt that broke got loose and then caught under the bull gear and broke a hole in the bottom of your Transaxle housing....Sorry... 1 Share this post Link to post Share on other sites
R. L. Addison 300 #7 Posted May 9, 2020 It would be my thinks that one of the 5/16 tie bolts that hold the differential together has broken and gotten under the bull gear and punched a hole in the bottom of the casting. This was not really uncommon among pre '75 or '76 tractors with the bigger engines that were used under heavy load conditions such as loaders. this happened to my '74 C160 within a year after I bought it new. It also happened to my 1075 and the case got broken on it, so I knew to shut down the C160 before I broke the case. There is a service bulletin on this problem. Braze the case or replace as needed, drill bullgear & hubs for 3/8 bolts (grade 8) & problem solved. 1 Share this post Link to post Share on other sites
