Jennifer
WT-30 Tiller
Jennifer
Needing someone that has one of these WT-30 tillers to please load pictures of the belt tension thingy!  We know there has been two at the big show one this past year another the year before!  Hopefully they are members here!  If so and you would be so kind to help us with this, Thanks in advance!  Husband is trying to get ours useable.  He got a 32" belt but something isn't going his way!  LOL!  Every thing we have gotten on this tiller shows a Kohler K91.  We have in fact a Clinton 1200 that runs fabulous!  The Tiller does not appear to have ever had red paint on it.  Engine and tiller paint match.  Also we are looking for the speed reduction to slow the tractor, CC-60 conversion assembly!  Thanks everyone!
Edited by Jennifer
Jennifer
Is there anyone that can help us out?
littleredrider
What belt are you looking for? The tiller has it's own motor, and doesn't look like needs a belt?
R Scheer
I believe she's talking about picture #3, the clinton motor to the tiller.  There is a copy of the manual on the site, doesn't show a picture of the belt.  It does say the Kohler motor though.
Is the idler pully flat or v shaped?
Can you use a piece of rope to confirm the belt length?
littleredrider
missed that lol
Jennifer
The belt from the motor to the gear box that turns the tines!
Edited by Jennifer
Jennifer
V pulley but need pictures of someone’s that have it working to see if the belt Tensioner is right?  The belt the Manuel calls for is to big or so it seems!  Thanks for the reply
Jennifer
Anyone?  Help !!!  Lol
jsp_333
Jennifer Still looking for help on this? I literally brought one of these home today. Found this thread while trying to identify what I actually bought.
Mine has the k91 on it so don't know if that disqualifies it. Let me know
Darb1964
That lever up front seems like that should engage the tines, seems like the belt should go,if the idler pulley is flat, the flat part of the bet should push against it. If v the belt should pull in to it when lever is engaged. Something like that, seems like there should only be two options.
jsp_333
Darb1964 is correct  - that lever on the front is used to tension the belt and engage the tines.
Jennifer was that the issue or were you having a different problem?
gwest_ca
To add to the confusion there are 4 different belts listed for the tiller drive and speed reducer.
Garry
Jennifer
YES PLEASE!  PICTURES would be of great help!  Thanks!
Jennifer
Different. Would like a picture of the belt how it is can what it looks like to see if what we have is all here!  We relize how to in gage the tines.  Third picture in this post I would like a close up picture of this area!  Thanks.  We are going to switch out the engine to a K91 but in need of picture of question area!  Want to match things up!
Edited by Jennifer
jsp_333
Ok give me a week or two. I'm going to have to put it back together.  and I'm away this weekend and on a deadline at work next week but I'll get it to you.
jsp_333
Actually I just found a bunch of images I took when I brought it home.
They're reduced in size for this site but I have full size images if you need more detail.
Also what you see may not be correct for actual operation. I have not tried to get it working yet.
I think the belt on the centre pulley should go down the inside not the outside of pulley as in pics.  just double checked. I believe the pictures are correct.
the centre pulley pivets outwards to engage the drive on the tiller.
Again it'll take a week or 2 to put it all back together if you need more pics.
Let me know how you make out.
Cheers, john
Edited by jsp_333
incorrect information
  • Thanks 1
Jennifer
@jsp_333  Thank you so much great pictures!  I will show the hubby and see if it helps!
  • Similar Content
    • Epayne85
      By Epayne85
      Hello all, I have a what I believe is a 36” tiller.
      i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
      edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01636
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04041
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • D_Mac
      By D_Mac
      Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • bigbuck
      By bigbuck
      I'm not positive of the model, but I think I'm close. Please call George at 517-499-5678
