71_Bronco 1,072 #1 Posted May 4, 2020 For those of you running wheel weights on your tractors, do you run them year round? Why or why not? I have a Commando 8 that I'm looking into weights for since I use the tractor to plow. In the summer, I also use it to mow. My lawn is flat, so I dont need the extra traction to prevent sliding. Will weights be bad to run in the summer? Or give me no extra benefit? Thanks! Share this post Link to post Share on other sites
WHX?? 48,791 #2 Posted May 5, 2020 Depends on what type of tire you are running. Turf tires pretty much safe to leave them on year round. Ags probaly not so much so. Especially if you have soft ground. 2 Share this post Link to post Share on other sites
71_Bronco 1,072 #3 Posted May 5, 2020 I'm running Kenda K502 Terra Trac's on all 4 corners. 2 Share this post Link to post Share on other sites
WHX?? 48,791 #4 Posted May 5, 2020 Oooooo I like those.... kinda in between agressive and mild. I wouldn't be afraid to run weights on them year round.. just watch for spinning you get in wet stuff. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,373 #5 Posted May 5, 2020 I run AGs fluid filled and cast iron weights year round maybe I'm just too lazy to pull the weights but either way I haven't hurt the yard and on my sub compact diesel mowing machine I run R4s with fluid filled rears again no turf damage only you can be the final judge of what you want to do each fall and spring or not. 1 Share this post Link to post Share on other sites
ebinmaine 67,307 #6 Posted May 5, 2020 7 minutes ago, WHX24 said: Oooooo I like those.... kinda in between agressive and mild. I wouldn't be afraid to run weights on them year round.. just watch for spinning you get in wet stuff. I'll second that. We don't mow with our tractors so I can't opine on that. We keep weights all year for forest in summer and snow in winter. On Cinnamon I run 4 oversized AND fluid filled tires all year. Fluid weight alone is 255 lbs. 1 Share this post Link to post Share on other sites
WHX?? 48,791 #7 Posted May 5, 2020 1 minute ago, WVHillbilly520H said: maybe I'm just too lazy to pull the weights Took the words right outta my mouth Jeffrey... I do rip across my lawns with loaded ags and weights on the plow tractors with no ill effects. Just wish my visiting plow brethren would lift ther plows! 10 Share this post Link to post Share on other sites
Pullstart 62,800 #8 Posted May 5, 2020 33 minutes ago, WHX24 said: . Just wish my visiting plow brethren would lift ther plows! you got a twin Jim? 3 Share this post Link to post Share on other sites
lynnmor 7,302 #9 Posted May 5, 2020 I don’t run wheel weights while mowing because of soil compaction. Share this post Link to post Share on other sites
JAinVA 4,619 #10 Posted May 5, 2020 (edited) Sounds like a good reason to get another horse to use.One with weights for the tasks that require extra traction and one without to mow with.This of course comes from someone who had only one for many years.It was fitted year round with weights and chains even to make my weeds the same heigth.. Edited May 5, 2020 by JAinVA 3 2 Share this post Link to post Share on other sites
Greentored 3,201 #11 Posted May 5, 2020 I run a pair of pretty aggressive rears (SunF G003) and front turfs on my 520, all four corners loaded to the max with washer fluid. Pulls a plow, drags brush and a variety of implemements, rips out stumps, etc... and zero lawn damage while cutting grass, even on steep hills and ditch sides. Soil compaction not an issue here, its good ole NC clay- weighted or not, its like concrete anyhow haha. 1 Share this post Link to post Share on other sites
WHX?? 48,791 #12 Posted May 5, 2020 11 hours ago, JAinVA said: good reason to get another horse to use. I'll second that 1 Share this post Link to post Share on other sites
ebinmaine 67,307 #13 Posted May 5, 2020 1 minute ago, WHX24 said: I'll second that Really Jim? Second? That's what we're going with? Shouldn't it be more like I'll 25th that? 1 1 Share this post Link to post Share on other sites
formariz 11,987 #14 Posted May 5, 2020 I keep them all year. Once you get used to the ride with weights ,without them it just does not have that solid feeling. Many times I use tractor also to pull a heavily loaded small trailer so its ready all the time. Even devised an attachment to place weights in front using mule drive to improve steering when pulling load.Back of property is a bit bouncy too so weight makes mowing back there a lot easier on my back. 1 Share this post Link to post Share on other sites
