ZXT
School me on Kohler electronic ignition
ZXT
This isn't on a WH (yet), but I figured I'd ask since I'd never seen this system before.
Yesterday, I bought a K301 from my neighbor off of a Lincoln Roughneck welder. It has some sort of magneto ignition on it. He had been running it with a traditional coil and points setup for testing, and hadn't tried the magneto ingition.
I hooked the original ignition system back up to the points and condenser, and it fired right up. It is electric start, but has a pull rope pulley and doesn't appear to have a stator, unless the wires are tucked away somewhere. I'm assuming the generator on the welder charged the battery? Seems odd that a welder would put out 12v DC, but then again I'm not familiar with them.
If any of you have come across such a system and can share any info, I'd appreciate it!
ebinmaine
:confusion-shrug:
:popcorn:
Pullstart
If you have a spare side plate and stator flywheel combo, you could easily swap it out!
953 nut
In the early '80s I had a Lincoln powered by a Kohler 12 HP and the welder did have a battery charger built in. It was so dependable that I never had to work on the ignition with the exception of spark plugs.
Have you removed the engine from the welder yet? Most engines that are directly coupled have a tapered crank shaft.
ZXT
Would that require converting to battery ignition? I haven't pulled the shroud off to see what the ignition setup is like, but I suspect that it is under the flywheel in place of the stator. If that's the case, I'm just going to leave it alone. I plan on putting it on the 800 special I picked up a while back. I don't plan on having anything on it to draw power.
That's probably the case with this one then. Engine has been removed from the welder for a while. It does have a tapered shaft, so I'll have to get creative to make it work or swap the crank out.
ebinmaine
7 minutes ago, ZXT said:
make it work
There are adapters available.
@Achto or @Shynon maybe? I've seen one used by them?
Pullstart
the adapter by @Achto looks very similar to a 4.5” disc grinder if I recall.  How he made that funny shape fit on a crankshaft taper is beyond me!
oliver2-44
They probable just tap the welder stator part way through to get 12v.
At the dams we had some old 1940 vintage generator exciters that a multitude of taps connected to a sliding contact bar.  all the wires from the taps connected to a "Frankenstine looking "black ebony asbestos insulator board that had verticle rows of fixed contacts with a sliding  bar of contacts to provide varying generator excitation.
Achto
The tapered shaft on the engine that I had needed an extra step taken off in order to make the adapter fit.
I started with this.
Ground the shaft down to this.
Then installed the adapter.
The adapter that I used was taper to 1 1/8" keyed shaft. Here is a link to the taper to 1" and a link for taper to 1 1/8".
https://www.ebay.com/itm/Crank-shaft-Adapter-Taper-to-1-Inch-Generator-Pressure-Washer-Engine-bushing-/132083677591
https://www.ebay.com/itm/Crank-shaft-Adapter-Taper-to-1-1-8-Inch-Generator-Pressure-Washer-Engine/111797583847?hash=item1a07a7bfe7:g:wOYAAOSwA4dWHr9t
As for the electronic ignition with a charging stator. Normally most of the stator is wound for charging the battery, 2 or 3 of the posts on the stator will be used to run the ignition.
ZXT
Thanks guys. This engine has a fairly stubby output shaft, that is like 1.5" diameter. I'll have to get exact measurements and get to looking for an adapter.
