wvhunter
turning plow hook up
lynnmor
I think it is pretty much the same as what everyone is using.
wvhunter
I hope so,it looks kind of big for the tractor.thanks
wvhunter
I think that it can be adjusted, like lowering the front
daveoman1966
You'll need this CLEVIS hitch...  some call it a SLEEVE hitch.
  • Excellent 2
Pullstart
I can’t tell, but that looks like a 10” plow at the max.
Hot Wheels my 953 is a 12 hp and Putt Putt my customized 502 is only 8 hp.  They both pull a 10” plow.
wvhunter
do you think I can hook it up the way it is? looks like it sets high in the front to me.thanks for the help
Pullstart
You’ll have to set up the plow for the tractor, but it’s adjustable.  Check out the Brinly plow manual.  It is a bit of a read, but well worth it.
here’s a thread in our instructions section.., it goes over a thing or two!
Rolling dirt
jshort
Hi, I just received this hitch. is there anything else needed to hook it up? Like cables chains etc. New to all of this but find it interesting and I'm kind of handy. My tractor is the 74 b-100 has a 14 hp engine not sure if that is original but it looks like. Would be grateful for any info.
Edited by jshort
didn't check the notify box, just in case.
wvhunter
I think you will need a rock shaft kit also, I am new to this also
daveoman1966
You need the CLEVIS HITCH shown in this schematic...EXCEPT for item # 2, 22, as they are for aAUTOMATIC tractors...yours is manual.
Look and see if you already have # 21...the cable tube. It'll be under the seat...on top or the transmission case.
You can buy MOST of these parts here:
https://www.psep1.biz/arinet.asp?aribrand=TO#/s/TO/85518//1/
Lowell at WHEELPARTSANDMORE will probably also have what you need at much better price.
https://wheelhorsepartsandmore.com/
Large
WVHillbilly520H
@wvhunter, if you don't already have you will need a lift cable and rockshaft kit along with a clevis hitch like this https://www.wheelhorsepartsandmore.com/hitches-liftkits.html#!/Toro-Wheel-horse-Rock-shaft-kit-man-trans-short-clevis-READ-DESCRIPTION-w-Tube/p/84960096/category=23548047 and https://www.wheelhorsepartsandmore.com/hitches-liftkits.html#!/Toro-Wheel-Horse-Brinly-Clevis-Hitch-Sleeve-Hitch/p/84960065/category=23548047... And that Craftsman plow is just a rebranded Brinly 10" and it is adjusted with that top handle after its hitched to your tractor.
wvhunter
thanks for the help
jshort
Appreciate all the help with the links and schematics. understand how this works now.  Your all very helpful  Thank you.
