Sam Pasch 449 #1 Posted May 1, 2020 I have a short frame 867 that I am looking to get a snow plow for. I am having trouble finding one for a short frame in my area. Would it work to get a long frame plow and cut it down shorter? Also, what would be a reasonable price? Thanks, Sam Share this post Link to post Share on other sites
ebinmaine 67,306 #2 Posted May 1, 2020 No need to cut it Sam. Trina uses along frame plow on her 867 and it works perfectly fine. 1 Share this post Link to post Share on other sites
Ed Kennell 38,028 #3 Posted May 1, 2020 Average price for plows and frames are $150 in my area. Axle brackets are $30-$50. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,033 #4 Posted May 1, 2020 Here is a list of the dozer blades. Notice in 1968 the long frame tractor dozers will also fit the short frame models by moving the rear crossbar ahead about 6 inches. When that happened the rear axle hitch was moved to under the rear axle instead of in front of it. Dozer DNA of short tractor frame dozer blades 1961 model BD-4271 - Fits SHORT frame tractors - Mounts ahead of the rear axle - replaced by 1962 model BD-4262 - Fits SHORT frame tractors - Mounts ahead of the rear axle 1963 model BD-4263 - Fits SHORT frame tractors - Mounts ahead of the rear axle 1964 model BD-4264 - Fits SHORT frame tractors - Mounts ahead of the rear axle 1965-1966 model BD-4264A - Fits SHORT frame tractors - Mounts ahead of the rear axle 1967 model BD-4267 - Fits SHORT frame tractors - Mounts ahead of the rear axle 1968 model 6-2111 - Fits SHORT frame tractors - Mounts ahead of the rear axle ----------------------------------------------------------------------------------------------------------------------------------- 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - replaced by 1969 model [6-4112 + 6-9621] 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) -------------------------------------------------------------------------------- 1984-1989 model 06-48BC01 (They are now 48" wide) 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) Garry 1 Share this post Link to post Share on other sites
Sam Pasch 449 #5 Posted May 1, 2020 Thanks for the info guys. I plan on making my own mounting brackets so that's some money saved. Does a long frame plow stick out much further in the front? 1 Share this post Link to post Share on other sites
stevasaurus 22,711 #6 Posted May 1, 2020 @Sam Pasch Get in touch with Smokin" Joe in Polo, Ill...I'm almost positive he would have what you need. 815-590-7395 He used to live in Lanark. Mention my name. The long frame is about 4" longer then the short. Get the short frame...the fulcrum is in the right place. 2 Share this post Link to post Share on other sites
