ebinmaine 67,497 #2126 Posted May 20, 2021 8 hours ago, 8ntruck said: the crank case is connected to the intake manifold ahead of the intake valve so that the 50:1 fuel/oil mix gets drawn in to lube the bottom end during the exhaust stroke so it gets oiled like a 2 stroke That's a cool idea. Share this post Link to post Share on other sites
Horse Newbie 7,069 #2127 Posted May 20, 2021 Cable and internet restored... Put the baby raccoons by the tree last night...momma made 3 appearances last night before we went to bed. This morning all 3 are gone...hope she got them ! 1 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2128 Posted May 20, 2021 I always have carb issues with small engines, like weed eaters etc. Must be our ethanol concentrations here locally and our winter weather. Never get more than a season before havin to go through everything all over again...grrr. Finally got myself a battery powered weed eater for the routine stuff! 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #2129 Posted May 20, 2021 If you can't find non-ethanol gas, I would run it dry before long term storage. I can get non-ethanol, and I use Sta-bil just for good measure. Anything that sits months with cranking gets run dry before storage 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2130 Posted May 20, 2021 (edited) Thats what I do for the stuff only I run. but, you know how it it is, so n so needs ta borrow this an that and they don't return it till theres snow on the ground, or put it away without following instructions. Then Mrs wonders why the weed eater or little generator wont start. UGHH. Only I tend to the mid size stuff, mini bikes, chipper, auger etc. All those I kill the fuel feed, let the carb run dry and add some stabil if there's fuel left in the tank. Dug only gets non-ethanol lol Edited May 20, 2021 by Wheel Horse 3D 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #2131 Posted May 20, 2021 Yes...I hear ya loud and clear... I have a pressure washer. Had it maybe 3 years...the pump went out. The pump had built up that white stuff that gets on aluminum since aluminum doesn't rust. I had not adhered to the manual which said to use "pump saver" for long term storage. Also after the first winter would not crank...that's when I started running it dry before storage. After the pump replacement (I ordered of Fleabay) I started priming the pump with pink RV antifreeze(cheaper than pump saver) before storing. 2 Share this post Link to post Share on other sites
ebinmaine 67,497 #2132 Posted May 20, 2021 1 hour ago, Wheel Horse 3D said: I always have carb issues with small engines, like weed eaters etc. Must be our ethanol concentrations 13 minutes ago, Horse Newbie said: If you can't find non-ethanol gas, I would run it dry before long term storage. I can get non-ethanol, and I use Sta-bil just for good measure. Anything that sits months with cranking gets run dry before storage We stopped putting any ethanol in any of our equipment maybe 4 years ago. No other chemicals needed. 1 Share this post Link to post Share on other sites
Horse Newbie 7,069 #2133 Posted May 20, 2021 1 minute ago, ebinmaine said: We stopped putting any ethanol in any of our equipment maybe 4 years ago. No other chemicals needed. You done started it now...snake oil debate ! 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2134 Posted May 20, 2021 our non ethanlol is just so 'spensive. I have found though that all our local stations are NOT equal in ethanol content on their gasoline. So I've selected the lowest concentrations station to shop at. A few cents more maybe, but not 30 percent more like the full non ethanol. 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2135 Posted May 20, 2021 (edited) I do need to do something about gettin those weed eaters goin', I just don't look forward to the busted knuckles that result EVERY time I tear into somethin! LOL Other day helped son troubleshoot a shoot a weed eater he picked up trom TSC. He bought it half price and we had it goin in an hour or so. He saved over a hundred, and it cost ME sore knuckles.(they had inverted the disk right behind the replaceable head, so you couldnt put a pin in to keep it from spinning and overtightened it so id put too much drag, flipped it, works perfect.) Maybe I need to try some of Dennis' seafoamish concoction, Or maybe do somethin custom with those ingredients for cleanin these up. Edited May 20, 2021 by Wheel Horse 3D 1 Share this post Link to post Share on other sites
ebinmaine 67,497 #2136 Posted May 20, 2021 17 minutes ago, Wheel Horse 3D said: I do need to do something about gettin those weed eaters goin', I just don't look forward to the busted knuckles that result EVERY time I tear into somethin! LOL Other day helped son troubleshoot a shoot a weed eater he picked up trom TSC. He bought it half price and we had it goin in an hour or so. He saved over a hundred, and it cost ME sore knuckles.(they had inverted the disk right behind the replaceable head, so you couldnt put a pin in to keep it from spinning and overtightened it so id put too much drag, flipped it, works perfect.) Maybe I need to try some of Dennis' seafoamish concoction, Or maybe do somethin custom with those ingredients for cleanin these up. I don't mess with 2 stroke engine machines. I have a great small engine shop that "reads" them better than I do. There are folks on here such as @Digger 66 that speak 2 stroke. 2 Share this post Link to post Share on other sites
Jeff-C175 7,202 #2137 Posted May 20, 2021 (edited) Slow but steady progress... Quite the improvement if I do say so: OLD Replaced all the rotted window frame with pressure treated, reproduced sash, primed and glass installed. I've forgotten how much fun it is playing with glazing putty! But it's like riding a bicycle or sending Morse Code (CW), the skill returns quickly. AND REPAIRED: There will be 1X4 trim around this when finished, and of course I'll caulk/seal all those openings first. While waiting for the PT wood to dry out enough to put some paint on it, I'm starting on the other window. Edited May 21, 2021 by Jeff-C175 2 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2138 Posted May 20, 2021 38 minutes ago, ebinmaine said: I don't mess with 2 stroke engine machines. They just seem durn fickle little buggers! 2 Share this post Link to post Share on other sites
lynnmor 7,306 #2139 Posted May 20, 2021 Found a wallet on the road and picked it up. There was only $103.50 cash in it but a ton of credit cards. Dropped it off at the police station and got a call about an hour later from a grateful lady. If there would have been a phone number inside we could have cut out the middleman. 6 Share this post Link to post Share on other sites
Stormin 9,981 #2140 Posted May 20, 2021 Been over at my mate's in Scotland. Been fitting a new door on his MF that ran away. The one below. Those doors are heavy and it put up a real fight to go on. Eventually we won. Found why two of the cab mounted work lights wouldn't. Need replacing so new ones to be got. With the new tombstone and the axle etc back on it looks more like it's old self. 2 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2141 Posted May 20, 2021 12 minutes ago, Stormin said: Been over at my mate's in Scotland. Been fitting a new door on his MF that ran away. The 12 minutes ago, Stormin said: Well, don't Stormin have some high toned friends! Look at ALL that lumber! Share this post Link to post Share on other sites
Stormin 9,981 #2142 Posted May 20, 2021 3 minutes ago, Wheel Horse 3D said: Well, don't Stormin have some high toned friends! Look at ALL that lumber! That lumber is now. 4 4 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2143 Posted May 20, 2021 (edited) Nice! Love the batten and board look! Might borrow some of those framing ideas there, nice utilization of larger timbers. Edited May 20, 2021 by Wheel Horse 3D 1 Share this post Link to post Share on other sites
Stormin 9,981 #2144 Posted May 20, 2021 You should see the workshop. It's finished now apart from a roller shutter door. 5 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2145 Posted May 20, 2021 DROOOOOLLLLLL! Whats the structure between the rafters and roofing metal look like? Is that just insulation foam? Any stringers in there? Share this post Link to post Share on other sites
WHX?? 48,815 #2146 Posted May 20, 2021 I got some plane tickets you wanna build one like that here Norm! Betcha the tickets be alot less than the lumber.. 1 6 Share this post Link to post Share on other sites
Stormin 9,981 #2147 Posted May 20, 2021 5 minutes ago, Wheel Horse 3D said: DROOOOOLLLLLL! Whats the structure between the rafters and roofing metal look like? Is that just insulation foam? Any stringers in there? That's box profile coated sheets with a layer of insulation coated on the underside. 2 Share this post Link to post Share on other sites
Stormin 9,981 #2148 Posted May 20, 2021 You should really see the inside now it's finished. Pity I've not a photo' or two. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,795 #2149 Posted May 20, 2021 NIce! very efficient use of materials there! No roof decking, no additional stringers, the box sheets of course probably cost a bit more, but add the rigidity for those longer spans between the rafters(3ft or so?). Nicely done! 1 Share this post Link to post Share on other sites
Stormin 9,981 #2150 Posted May 20, 2021 I need to make a correction. Those sheets have a sandwich of insulation between them. 1 Share this post Link to post Share on other sites
