SylvanLakeWH 27,176 #5801 Posted June 22, 2023 18 minutes ago, ohiofarmer said: a definite need to lose some weight, 5 minutes ago, ebinmaine said: I find that need nearly every move I make. I represent that... 1 Share this post Link to post Share on other sites
Achto 28,577 #5802 Posted June 23, 2023 Went for a ride on a 1942 DUKW "Duck". Only 4" clearance on each side through this gully. Hawks peak in the lower Wisconsin dells. 5 5 Share this post Link to post Share on other sites
Achto 28,577 #5803 Posted June 24, 2023 Waiting to see Kenny Wayne Shepherd. 4 1 Share this post Link to post Share on other sites
Stormin 9,983 #5804 Posted June 25, 2023 Green, lawn, verges and bridleway mown this morning. Good timing as the rain from the Big Show has just made it over the Pond. 1 2 Share this post Link to post Share on other sites
8ntruck 7,326 #5805 Posted June 30, 2023 (edited) I've got a couple of projects going. First, I have gotten the travel trailer de-winterized today. Flushed & sanatized the plumbing system, unloaded some of the camping supplies that were being stored, washed the awning, set the tires to proper pressure, and convinced the water heater that it needed to work properly. Still need to replace the battery, as it is not holding a charge. Second, I'm in the demolition phase of the lake house bathroom remodel. The shower, vanity, toilet and old vinyl floor have been removed. I have about 30% of the vinyl floor adhesive scraped off. Fortunately, it responds well to heat. The ca. 1960 black mastic floor tile beneath it, not so much. The new floor is scheduled to be ceramic set with thinset. Has anybody else out there set ceramic tile over old black mastic? I'm planning on using a primer over the mastic that is rated to encapsulate any asbestos and leave a suitable surface for thinset. Oh, yea. For grins and giggles, I saw the doctor today about a fluid filled 'bubble' that appeared overnight on one of my elbows. Bursitis, she says. What do I need to do to get rid of it, I ask. Don't bump it, don't aggravate it and it should go away. How long I ask. I dunno, she says. Maybe a couple weeks, or months, or, maybe never. Geten' old ain't for sissies. Edited June 30, 2023 by 8ntruck Share this post Link to post Share on other sites
ohiofarmer 3,323 #5806 Posted June 30, 2023 (edited) Update on the gas pipe replacement. Hopefully some useful information you can use. We all know that once you start the chain of order in replacing pipes, it is not easy to predict exactly where they will wind up. The installing crew for the new Fart Smeeter [Smartmeter] did me a solid by extending their one inch pipe beneath the crawl space and placing a very expensive and uSA made union in the middle of their run. They also placed a shut off valve in the run and put a one X three quarter pipe connector for me to attach my run of pipe to.Very nice of them since the owner is responsible for everything on the customer side of the meter. The union is something entirely necessary if that pipe is gonna leak so you can loosen it up and spin the joints together , making the elbows and such come apart and go together. I simply ran the pipe and sighted back toward the joint and laid it on top of a five gallon bucket.....then mounted a pipe strap to hang it temporarily to assemble the joint . Not fun to do when crawling along consists of your forearms and pushing with your toes The inspector from the gas company told me that i should test it at three to ten pounds and i have a Kuhlman gauge, so not a problem. Well, it was because the dial gauge on it was not acceptable and the new digital stuff they use can test higher pressure and also find tiny leaks at the appliance at low pressure. So then I just used a mix of Dawn and water and it picked up the leaks at eleven pounds indicated pressure and passed after failing the first time. I did have to replace a half inch union in the furnace room, because unions have a copper crush in the inside that could as damaged in previous use. Things are not good when working with pipe in a tight area. The hardware store pipe and fittings can say China and Vietnam and some are so bad they will not thread together. it pays to have a nice rigid pipe threader onsite to make things fit better. 3/4 pipe is 2.50 per foot and fittings are at least that much. I did some recutting of threads on some USA stuff, and they have the ductility correct for better quality. It was a good thing that I did not have this house out in the county as it would have required an inspection by county inspectors and probably a repeat fee if it failed The village the house is in has no association with zoning or building inspection and people seem to still survive. Centerpoint Energy did me a solid and would come any time day or night to , and restore service.. Running a gas line past your property makes you pay about 40 dollars a month whether or not gas is used, so at least they treat you like it matters. So , fellas, remember that a gas pipe union can save you hours of headache in case you have to take things apart.....Maybe a second union on the longer runs in tight places. Edited June 30, 2023 by ohiofarmer 1 Share this post Link to post Share on other sites
Achto 28,577 #5807 Posted June 30, 2023 What did I do today. Not a whole flippin' lot. 4 4 1 Share this post Link to post Share on other sites
WHX?? 50,476 #5808 Posted June 30, 2023 1 minute ago, Achto said: What did I do today. Not a whole flippin' lot. Fish cooperating? Looks like barnyard buzzard... 6 Share this post Link to post Share on other sites
Achto 28,577 #5809 Posted June 30, 2023 14 minutes ago, WHX?? said: Fish cooperating? Looks like barnyard buzzard... Ain't even put the boat in the water yet. Share this post Link to post Share on other sites
davem1111 2,091 #5810 Posted June 30, 2023 Power went out around 3:30 pm yesterday. Have 2 generators but one wouldn't run, even though I switched to non-alcohol gas a while back. Had to tear down and clean the carb, then it ran fine again. Power was out for about 25 hours. Branches and limbs all over the place, big pine tree took the power lines down to my neighbor's house across the road. When I couldn't get the second generator running this morning, I decided to run out to see if I could buy another one, then fix this one later. Lowe's said they sold out by 9am, Menards was out, Rural King was out, Harbor Freight was out, and said they had a line waiting at the door before they opened this morning. Didn't think I'd want to have a "spare spare" generator, but now I do. Mainly to preserve the food in 2 fridges and one freezer, but also to retain the sanity of other family members who are not very happy when the power goes out... 2 3 Share this post Link to post Share on other sites
ebinmaine 70,316 #5811 Posted June 30, 2023 36 minutes ago, davem1111 said: a "spare spare" My uncle Ron would tell you... "If ya need one of something, ya need two". 3 1 Share this post Link to post Share on other sites
WHX?? 50,476 #5812 Posted July 1, 2023 1 hour ago, davem1111 said: also to retain the sanity of other family members who are not very happy when the power goes out... Remind them of how pioneers lived... 1 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,176 #5813 Posted July 1, 2023 Two words: generator... Well, one emoji and one word... 2 1 Share this post Link to post Share on other sites
JCM 9,991 #5814 Posted July 1, 2023 Cut the grass with the 310-8 and then took the old Chevy out for a ride in the country. It really makes you realize that you don't need half of the gadgets that the newer model trucks have to enjoy the ride. The 4 speed manual makes the ride even more enjoyable. 1 2 9 Share this post Link to post Share on other sites
davem1111 2,091 #5815 Posted July 1, 2023 11 hours ago, SylvanLakeWH said: Two words: generator... Well, one emoji and one word... Funny, that. I actually told my wife at one point that I had seen pictures of a generator mounted on the front of a Wheel Horse, and wished I had one. I have 3 running tractors and one sort-of-running-and-better-after-the-new-carb-gets-installed, so the engine wouldn't be a problem. So I'm wondering: was that an official WH attachment, or home-built? Or both? I already have a home-built 2" receiver that goes on the mule attachment, so it wouldn't be difficult to adapt a generator. I have several electric motors - can those be reverse-engineered to work as a generator? 2 Share this post Link to post Share on other sites
Ed Kennell 40,236 #5816 Posted July 1, 2023 https://www.bing.com/ck/a?!&&p=c36c80818795d5d8JmltdHM9MTY4ODE2OTYwMCZpZ3VpZD0xZjMzOTNlMi0xMTRhLTYwZGEtMTI4Mi04MGRjMTAwNTYxNjYmaW5zaWQ9NTcxOQ&ptn=3&hsh=3&fclid=1f3393e2-114a-60da-1282-80dc10056166&u=a1L2ltYWdlcy9zZWFyY2g_cT13aGVlbCBob3JzZSBnYW5lcmF0b3IgcGljcyZGT1JNPUlRRlJCQSZpZD0xMzlDQjIxM0U1MDZEQUIwMDhCODE5NThEMkQ3RjZCODQ2NjdDOEU2&ntb=1 1 1 Share this post Link to post Share on other sites
Achto 28,577 #5817 Posted July 1, 2023 (edited) 10 minutes ago, davem1111 said: So I'm wondering: was that an official WH attachment, Wheel Horse generators were an official attachment. The generator was made by Generac then branded as WH. I know that a generator will run as a motor for a short time, until the diodes on the field coil burn out. To make a motor into a gen would be a challenge. Would need to add a field coil to regulate output power. A regulator would be needed, then I would not be sure if the windings would hold up. You would be better off to find a belt drive generator & adapt it to a tractor. Edited July 1, 2023 by Achto 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,176 #5818 Posted July 1, 2023 (edited) 40 minutes ago, davem1111 said: So I'm wondering: was that an official WH attachment, or home-built? Or both? i've seen both. They pop up for sale now and then... last one i saw was NOS... can't remember where though... Post a want ad... Edited July 1, 2023 by SylvanLakeWH 2 1 Share this post Link to post Share on other sites
Tractorhead 9,087 #5819 Posted July 1, 2023 Built today a new Barbecue and Griller Place. The old floor was rotten, so it was urgently time to rework it. Now i have ad a Griller‘s Chair with a small Sideboard to the Pavillion side added. Kati paints the Wood to make it more Weatherproofing. We get the Wood from a Farmer as gift for my Fawn Saving tasks from 2 Valley‘s ahead. - a classic Win win situation for all. 3 5 Share this post Link to post Share on other sites
Tractorhead 9,087 #5820 Posted July 1, 2023 And later the Evening, it can be also used as Fireplace.... so have a nice Weekend lads 3 2 1 2 Share this post Link to post Share on other sites
ebinmaine 70,316 #5821 Posted July 1, 2023 (edited) Me n The BBT went a couple mountains over to Mt Cutler today. The trail starts right near the old East Hiram ME Railroad Station area. It hasn't been used for decades but is still in possession of the RR company. Many moons ago Hiram was a large enough station to warrant a track siding for switching RR cars around. This hole in the forest floor is one of several water cisterns used for storage for the steam trains. The station was also a stopping and refilling point. These water storage wells are part of a stream that runs year round. The bridge across the Saco River is visible in the distance. A few more pics... Edited July 1, 2023 by ebinmaine 2 4 1 Share this post Link to post Share on other sites
ebinmaine 70,316 #5822 Posted July 1, 2023 Trina and her mom decided to stack some firewood. This shed is roughly 2, 2.5 cord when stuffed. It's a bit over half full right now. 3 1 Share this post Link to post Share on other sites
Wheel-N-It 2,971 #5823 Posted July 2, 2023 Thanks to all who posted todays pics 1 Share this post Link to post Share on other sites
WHX?? 50,476 #5824 Posted July 2, 2023 On 6/30/2023 at 7:47 PM, JCM said: It really makes you realize that you don't need half of the gadgets that the newer model trucks have to enjoy the ride. Amen Plunger... evertime I hop in one and that touch screen says all this bull crap about keeping eyes on the road... well then why the heck give me those distractions?!?! How about a three on the tree instead?!?! Excuse me for showing my age... 2 2 Share this post Link to post Share on other sites
WHX?? 50,476 #5825 Posted July 2, 2023 On 6/30/2023 at 6:15 PM, Achto said: Ain't even put the boat in the water yet. Well look where that got you now! I'll let him explain fellas! 1 Share this post Link to post Share on other sites
