Mickwhitt
What did you do today?
Stormin
 Went to help my mate Dunc load his 1952 Land Rover S1 at his stepsons. This is an ongoing restoration as time allows. So far about 10yrs. He's taken it up to his property in Scotland. Body work etc was taken up there last week. Maybe progress, just maybe, things will get done a bit quicker.
Edited by Stormin
  • Excellent 2
Wheel Horse 3D
Pretty usual day a work, actually got my hands a little dirty helping out one of the other departments with greasy sandy wiring. Tonight may be a trash pickup, and likely more trash tomorrow morning to the dump etc.Hopefully sometime I can finish up a print project by Monday and perhaps Sunday dig into gettin Dug prepped for Big Show(remove deck, paint rims and weights,some cleaning and Water Displacement Formula No. 40 etc.)
Edited by Wheel Horse 3D
ebinmaine
Well let's see. I... Drove the truck around. Unloaded it. Got another truck. Did the same thing.
  • Haha 2
Tractorhead
I started today the Basement of the new Pavillon i will build.
Firstly the main Posts than the Main Bars.
at least i be able to fix the distances with 2 Sidebars.
and yes, it‘s no optical illusion, the front right post is 5cm deeper compared to the rest
to get later a dedicated direction to catch the Rainwater from the roof.
But after it begins to rain i decided to go into the Workshop when i meet Harrold.
He is a young Fox, very curious.
When he see me, he gets in a Panic Attack and flee the fast as he can, but i can Capture him...
Back in the Workshop i reworked the electric Powersteering for the Backhoe Project.
It‘s worth a try if this will work.
  • Excellent 2
Wheel Horse 3D
And just placed an order for a bunch of square business cards
Wheel Horse 3D
4 minutes ago, Tractorhead said:
and yes, it‘s no optical illusion, the front right post is 5cm deeper than the rest
Boy im glad you said somethin! I thought i was goin bonkers. Was makin my eye twitch!:ychain:
(Just kidding ..i really couldnt tell)
  • Haha 1
Wheel Horse 3D
Storage and dump out in the heat UGGH!
But on the bright side scored a 1" axle, rims, and tire off an abused garden trailer at the d.ump. Then on the way home an stop by HF to pick up a new dial indicator, and found some cool 12"×12"  rubber diamond plate pattern adhesive tile. $4.20 including tax and i now have replacement traction stuff for Dugs foot boards!
ebinmaine
  • Like 5
  • Excellent 2
Jeff-C175
I thought of using that myself but opted for black skateboard skin instead.
I'd like to see it installed on Dug so be sure to post some pics!
Lee1977
48 minutes ago, ebinmaine said:
Trina does nice work.
Edited by Lee1977
  • Haha 1
ebinmaine
She does. Thanks Lee.
She's thinking about adding another row all around and that'll be it.
  • Excellent 2
Wheel Horse 3D
Hopefully git er done tomorrow! Hope 6x12 is good for each side
Stormin
How big are your feet? :D
  • Haha 3
ebinmaine
I do have a fairly large pair of boots that are over 13" long.
  • Haha 2
ebinmaine
When we built Cinnamon Horse C160 I put reddish step tape on.  Worked great but it's now overdue to be replaced.
I'd be curious but somewhat concerned about winter traction.
Looking forward to the pics.
ebinmaine
Yesterday Trina and I met up with friends to go hike Stone Mt and Burnt Meadow Mt in Brownfield Maine.
Nice leisurely paced  hike to help warm up the hiking muscles and start getting back in shape.
Here's a link that shows all the stats:
https://www.alltrails.com/trail/us/maine/burnt-meadow-mountain-trail
Burnt Meadow Mt is well known for a great caloric burn and good views.
Being within a 1 hour drive of several metro areas it's also VERY popular.
Here's a few pics from the Photography Department taken on @WHX24's camera.
Off in the far blue distance is Mt Washington and the rest of the Presidential Range
Here's a Rufous sided towhee. Not super common in the area.
Shown here is the range we live on as seen from the top of Burnt Meadow.
We're about 2/3 of the way down the far side where the arrow is.
More various....
  • Excellent 3
Wheel Horse 3D
Well.. MY feet arent THAT big! :ychain:
For the winter, thats kinda a fuzzy one...while the rubber may get cold and slippery, the knobbies(another Grey tech term) may not clog as easily as the sandpaper grit. For absolute best traction I bet a bit of extruded metal  on there would be perfect. Maybe 4 small bolts and washers?
Wheel Horse 3D
Looks like 12" is just right for between the bolts.
If ya wanted to do the hole step, looks like 18"
Would be preferable, the drill or cut out for the bolts? Then that might trap moisture around your bolts..hmmmmm.
Wheel Horse 3D
      I
Wheel Horse 3D
Progress!...
ebinmaine
On my tractors I find a significant wear area is right at the bend shown in my modified version of your pic.
Wheel Horse 3D
Mines not worn, but some PO black paint. Might try some acetone to clean that off carefully.
Then again, Dug isnt contending with big ol clodhoppers!:ychain:
  • Haha 1
Handy Don
      I
Its the moisture getting under the plate that would worry me. I wonder if a liberal spreading of rubber cement over the bottom of the plate would make a moisture-tight seal to the underlying footrest and eliminate the need for other fasteners?
Wheel Horse 3D
This has the same type backing adhesive as the traction tape. Seemed to have sealed and protected under there(where there were pieces left)
Wheel Horse 3D
Maybe just allow for water to run away from those 2 bolt heads.
