Razorback 1,068 #201 Posted June 7, 2020 Just keep laughin', Cvans....!!! 1 1 Share this post Link to post Share on other sites
Stormin 9,983 #202 Posted June 7, 2020 I retired at 62. Never been one for sitting around and have always kept busy with things at home, or at a friends farm when needed. Now at nearly 73, still doing the same things, I think rigor mortis is setting in. Bit of a worry when your still alive. 4 Share this post Link to post Share on other sites
formariz 11,993 #203 Posted June 7, 2020 On 6/7/2020 at 4:21 AM, Cvans said: My mind still comes up with goofy schemes but the body is now in control. I think that may be the best description of what eventually happens to most of us. Ultimately despite what the mind wants, the body controls everything. 2 1 Share this post Link to post Share on other sites
Stormin 9,983 #204 Posted June 7, 2020 Had a distancing social with most of the family out on the green. First time we've all been together for nearly 3 months. Weather has been considerate and sunny and warm. Been an enjoyable afternoon. 1 5 Share this post Link to post Share on other sites
meadowfield 2,650 #205 Posted June 7, 2020 finally glued the two halves of bendy with a propshaft! 6 Share this post Link to post Share on other sites
bc.gold 3,403 #206 Posted June 8, 2020 (edited) Fighting with the Ram, the bracket that secures the shock absorber is squeezed tight making it impossible to remove the old shock, think I'll have a controlled fire and burn the rubber out of the bottom eyelet. Drilled a small hole into the shock to remove the oil. Edited June 8, 2020 by bcgold Share this post Link to post Share on other sites
bc.gold 3,403 #207 Posted June 8, 2020 On 6/8/2020 at 12:34 AM, bcgold said: Fighting with the Ram, the bracket that secures the shock absorber is squeezed tight making it impossible to remove the old shock, think I'll have a controlled fire and burn the rubber out of the bottom eyelet. Drilled a small hole into the shock to remove the oil. Once the rubber grommet has been burnt the shock should just fall out. Share this post Link to post Share on other sites
bc.gold 3,403 #208 Posted June 8, 2020 On 6/8/2020 at 1:31 AM, bcgold said: Once the rubber grommet has been burnt the shock should just fall out. Mission accomplished. 4 Share this post Link to post Share on other sites
Pullstart 64,381 #209 Posted June 8, 2020 We camped at my brother and sister in law’s new place at the lake this weekend. After driving ‘cross town to dump tanks, Norman overheated. We pulled over for about 20 minutes, topped off the coolant reservoir and tried again. Overheating within a mile on a long grade, we coasted into town and left it in a parking lot in favor of bumming a ride from my golf partner. Ran to town for some thermostats, an A/C charge kit for him and some coolant. Then Mrs. P. found this Raider 10 right about a half mile from where we overheated, so we scooted over and grabbed that. We ended up limping Norman and the camper home a little at a time and spent the rest of the day in the pool and watering the garden. I’ll change the t-stats and flush it a few times with fresh water before filling back up with coolant. 5 Share this post Link to post Share on other sites
bc.gold 3,403 #210 Posted June 8, 2020 (edited) My ToDo list for the day just expanded, the pr-inspection safety on the Dodge Ram called for front rotors and brake pads and new shocks. The oil on the u-joint is from the hole drilled in the shock to eliminate the explosion factor, the u-joints aren't causing a problem at the moment, but you can clearly see one of the bearing caps has rust coming from the inside needle bearings. For $37.00 a U-Joint, I figure replacing them now will save me from doing them in sub zero weather. Edited June 8, 2020 by bcgold 1 Share this post Link to post Share on other sites
bc.gold 3,403 #211 Posted June 8, 2020 (edited) On 6/7/2020 at 4:21 AM, Cvans said: I retired at age 58. For the next ten years there was no holding me back. Except for being laid up for 6 months after and extensive back surgery and a short slow down for a heart stent. I was having way too much fun to set still. But this last year my age finally caught up with me and to be honest I'm just plain slowing down. My mind still comes up with goofy schemes but the body is now in control. Guess it's about time. Thankfully the sense of humor and the intellect still seem to be intact. I'm glad the 30 DeSoto came along as I've picked up a little steam again. At 71, my mind still hasn't synchronized with my physical limitations. But have learned when not to volunteer and let the youth do the heavy lifting. Edited June 8, 2020 by bcgold 3 Share this post Link to post Share on other sites
Stormin 9,983 #212 Posted June 8, 2020 Had a ride out this morning with SWMBO in the Hyundai. Had it a week now and she hadn't been in it. Happy to say she was impressed. Not a single complaint. Visited a couple of friends who we hadn't seen since the beginning of lock down. Social distancing out on the patio. Also had a look at the vintage motorcycles he was working on. Back home and dug out a bush that had to go. 3 Share this post Link to post Share on other sites
squonk 42,303 #213 Posted June 8, 2020 On 6/8/2020 at 4:15 PM, Stormin said: Had a ride out this morning with SWMBO in the Hyundai. Had it a week now and she hadn't been in it. Happy to say she was impressed. Not a single complaint. Visited a couple of friends who we hadn't seen since the beginning of lock down. Social distancing out on the patio. Also had a look at the vintage motorcycles he was working on. Back home and dug out a bush that had to go. No pics? Share this post Link to post Share on other sites
squonk 42,303 #214 Posted June 8, 2020 15 bales of cedar in the garden! 4 Share this post Link to post Share on other sites
Stormin 9,983 #215 Posted June 8, 2020 On 6/8/2020 at 5:05 PM, squonk said: No pics? 1 1 Share this post Link to post Share on other sites
squonk 42,303 #216 Posted June 8, 2020 HHHOOOWWWAAARRRDDD!!! and Buzz out helping trim some Pine & Cedars 4 3 Share this post Link to post Share on other sites
D_Mac 9,036 #217 Posted June 8, 2020 Should have used the 832 and the wooden cart !!! 1 Share this post Link to post Share on other sites
Pullstart 64,381 #218 Posted June 9, 2020 I built some anti theft bars for some skylights in a building that has experienced break ins... 2-1/8” tubing 1/8” wall, spaced with about 4” gaps. 14 bolts in each one holding them in. That aughtta slow them down at least! 3 1 Share this post Link to post Share on other sites
Razorback 1,068 #219 Posted June 9, 2020 Maybe add a fence charger somewhere in the design?? 2 1 Share this post Link to post Share on other sites
Stormin 9,983 #220 Posted June 9, 2020 On 6/9/2020 at 2:22 AM, Razorback said: Maybe add a fence charger somewhere in the design?? Wired to the mains supply. 1 1 Share this post Link to post Share on other sites
Pullstart 64,381 #221 Posted June 9, 2020 There are upgraded means of security now, but they wanted some added deterrent as well. Bust the skylight and see that? Odds are you will turn around and go away. 1 Share this post Link to post Share on other sites
Tractorhead 9,087 #222 Posted June 9, 2020 Burglars shy normally a long and hard Way, but it’s depending what they can earn. So maybe extra Long screws they hold the grid’s in place may be an improved stop. If they need an impact wrench to dismount the grids, it will also an additional loud timekeeper, additionally it occurs some noise in combination long screws cost them too much time. They mostly search for a quick and simple Way to go in. The hard a burglar protection is to remove, that more the safety is. 1 Share this post Link to post Share on other sites
Mickwhitt 4,962 #223 Posted June 9, 2020 Finished the driveway rail sleeper wall today, it's just the quickest way to make a retaining wall. I dont have the patience or skill to build a brick wall. 2 4 Share this post Link to post Share on other sites
ebinmaine 70,331 #224 Posted June 9, 2020 Looks great Mick! Share this post Link to post Share on other sites
bc.gold 3,403 #225 Posted June 9, 2020 (edited) Returned the brake caliper cores, then picked up couple of millimetre taps on the way home stopped in at a landfill we haven't visited for awhile. Both 0-30 DC power supply's work, have not tested the scope. Edited June 9, 2020 by bcgold 1 Share this post Link to post Share on other sites
