Achto 27,562 #7277 Posted September 30 (edited) 13 hours ago, WHX?? said: Buy stock in a toilet paper company along with a fire extinguisher outfit Not going down alone James, This stuff was made to share and I have every intension of making you a victim..... I mean... I plan on sharing this stuff with my good friends, you included of course. Edited September 30 by Achto 4 Share this post Link to post Share on other sites
WHX?? 48,813 #7278 Posted September 30 2 minutes ago, Achto said: sharing this stuff with my good friends, Plow Day??? 2 1 Share this post Link to post Share on other sites
oliver2-44 9,725 #7279 Posted September 30 39 minutes ago, WHX?? said: Plow Day??? Fiery jet powered plow tractor (drivers) 6 Share this post Link to post Share on other sites
ebinmaine 67,381 #7280 Posted September 30 6 hours ago, oliver2-44 said: Fiery jet powered plow tractor (drivers) 1 Share this post Link to post Share on other sites
Ed Kennell 38,108 #7281 Posted September 30 Couldn't wait any longer, for Helene to leave so I split and stacked the last blow down in the rain. 1 5 Share this post Link to post Share on other sites
ebinmaine 67,381 #7282 Posted September 30 (edited) Our road utility trailer has been knocking and rattling for awhile. Last trip in Sept down to @JCM 's for the Meet n Greet in N. Berwick things got real loud, real fast. Luckily I was almost literally across the street from my house. After some investipokingation I found that the spring eyelet bushings were worn right through. Also noticed the ball coupler was beyond worn to ain't usable anymore. Got most of the new parts. Now just need the time. This evening's fun was to begin removing the old coupler. I'm going from an OE 1970s welded on unit to a new bolt-on type. Increasing capacity. Also getting a quick attach. While there I'm changing the tongue jack from the standard screw down forever type to a quick drop/ then screw down type. Edited September 30 by ebinmaine 4 Share this post Link to post Share on other sites
953 nut 55,155 #7283 Posted September 30 23 hours ago, Achto said: . I still have a lot of stuff to take care of but I'm starting to run out of ideas I know you have seen these hanging around at Mexican Restaurants, they aren't just decorations. Use them just like you would use fresh ones when cooking. To hang dry jalapeño peppers, you can follow these steps: 4. Dry the peppers Hang the peppers in a well-ventilated area with low humidity for about four weeks. You can also dry peppers in the sun if the temperature is at least 90°F and the humidity is below 60%. 5. Store the peppers Once the peppers are completely dry, you can store them in an airtight container in a cool, dry place for up to one year. 1. Prepare the peppers You can leave the peppers whole or cut them in half lengthwise to help them dry faster. If you want to remove the seeds and membrane, you can do so now. 2. String the peppers You can use an upholstery needle and fishing line or a large darning needle and thread. Thread the needle through the bottom of the pepper's cap, also known as the calyx, to avoid puncturing the flesh. You can tie a knot at the end of the thread and keep adding peppers to the string. 3. Hang the peppers You can use thumbtacks to hang the string from the ceiling, or a coat hanger if you're short on space. Make sure the peppers aren't touching each other, as this can cause moisture to build up and lead to rot. Dried peppers are more potent than fresh peppers, and they can be used as a seasoning or in hot sauce recipes. 1 1 Share this post Link to post Share on other sites
WHX?? 48,813 #7284 Posted October 1 @Achto 2 hours ago, Ed Kennell said: I split and stacked Labeled different but same splitter I have... 1 Share this post Link to post Share on other sites
Achto 27,562 #7285 Posted October 1 Thanks @953 nut I've already dried a pile of Cheyanne peppers that I plan to use to make a powder. Guess I may have cheated a bit by using a dehydrator though. Great idea to dry out some jalapenos as well as some poblanos, both of which I like to cook with. 3 Share this post Link to post Share on other sites
WHX?? 48,813 #7286 Posted October 1 (edited) 52 minutes ago, 953 nut said: they aren't just decorations. Another thing we do it run them through the dehydrator then turn them to powder for seasoning. Lasts forever. Just make sure to label the zip locks on the heat level ! Edited October 1 by WHX?? Dan's a faster typer :) 1 1 Share this post Link to post Share on other sites
Mickwhitt 4,605 #7287 Posted October 5 Mrs.W wanted small log store to sit by the rear door. She had seen a few on the interweb and price was crazy at a couple hundred quid. Said it needed to look like a sentry box type of thing. So I gave it a go with just scrap timber and a large ceramic tile for the roof material. Top section for kindling and the main compartment for small logs. Just needs a shelf popping in and it's done. 5 Share this post Link to post Share on other sites
ebinmaine 67,381 #7288 Posted October 5 I spent some time cutting the rest of the coupler off the utility trailer. Also did some organizing in the barn. I put up a half sheet od pegboard where the electrical work desk is. Trina made up one of two doors for the new workshop space. 5 1 Share this post Link to post Share on other sites
Handy Don 12,201 #7289 Posted October 5 Moved the 854 up to the workshop/garage so it can undergo adaptation of its new-to-me dozer blade. The trickle charger said all was fine but when I tried to start it to get it up on the trailer the solenoid only gave the deathly stutter clicking. Jumped it from the car and off it went. I guess I got all that I could from that 10 yo battery! I left it running on the trailer for the ride across town (got a few strange looks) so I could get it up the steep driveway to the workshop before shutting it off! Moved the Snapper down to the house for the fall mowing and leaf pickups. 5 Share this post Link to post Share on other sites
ebinmaine 67,381 #7290 Posted October 6 13 hours ago, Handy Don said: I got all that I could from that 10 yo battery! 😮 Share this post Link to post Share on other sites
19richie66 17,500 #7291 Posted October 7 @Pullstart Here you go Kevin. Little bit of wood burning in between squaring up rafters. 1 5 Share this post Link to post Share on other sites
Pullstart 62,828 #7292 Posted October 7 I know that guy! Looks great! 1 Share this post Link to post Share on other sites
19richie66 17,500 #7293 Posted October 7 Made some switch covers today. Trying different things. 2 3 4 Share this post Link to post Share on other sites
adsm08 2,045 #7294 Posted October 8 I think I crossed into "old". Passed up a night out of the house, although the activity itself was not terribly appealing, to stay home and do laundry. 4 Share this post Link to post Share on other sites
Mickwhitt 4,605 #7295 Posted October 11 Shopping and packing for a few days in Portsmouth. It's one of our main naval cities and ports so I'm excited to see the museums and such that are there. HMS Victory is high on my list but the Mary Rose is our main attraction. Hoping to get plenty of photos but if anyone has any requests for images then just let me know. It's a 400 mile drive which for us is huge, I know that's practically in the neighbourhood for you guys in the US but for us it's a mighty long trip. Will be driving down on Sunday and staying till Thursday. 1 1 2 Share this post Link to post Share on other sites
peter lena 8,600 #7296 Posted October 11 @Mickwhitt been a long time since we were in england , but definitely remember the museums , thought the tower of london was incredible , the armory sections , armored elephants ! market gunners , the iron strap torture cages , dover castle , loved watching the grass cutting , down into the moats , maintenance people wearing ICE CRAMPONS , being lowered into the moats , they were all covered with grass . had a tour guide that was a graduate on the castle itself , amazing guide. thought the nessaseriam . on a sea facing wall , was interesting , basically an outdoor sit down toilet , cut into the top wall rock , dozens of rock cut seats . did not like the warm beer , turned off a meal , liked being in a street elevator , hearing all the different languages , loved the tour buses , driving thru london , people sitting at a table eating a meal , lower level . that started our traveling, pete Share this post Link to post Share on other sites
Mickwhitt 4,605 #7297 Posted October 11 Hi Peter. A lot of the armaments moved to the Royal Armories in Leeds. Now that is a museum to enjoy, armoured elephant and all. Portsmouth was a major naval base and still has a lot of naval connection now. London is not my favourite place, I've only been a couple of times and never really got on with it. Too big and impersonal for me. Sheffield is my nearest city and plenty big enough for me. Share this post Link to post Share on other sites
8ntruck 6,997 #7298 Posted October 12 I went to the local automotive swap meet today. Was pretty sparce. Maybe 'cause it was the 1st day of a 2 day event. Did not see anything that I needed to take home. I did see a 5.3 LS engine for $450. Been considering one of those as a swap into my '72 C10. Thought real hard about it, but finally decided that I have too many other projects to get to before making a swap in the truck. Besides, there was no transmission - that's my story, and I'm sticking to it. I noticed three types of wheels for sale that I had as projects while I was working. Kind of makes me feel old. 1 Share this post Link to post Share on other sites
ebinmaine 67,381 #7299 Posted October 12 1 minute ago, 8ntruck said: I went to the local automotive swap meet today. Was pretty sparce. Maybe 'cause it was the 1st day of a 2 day event. Did not see anything that I needed to take home. I did see a 5.3 LS engine for $450. Been considering one of those as a swap into my '72 C10. I do understand the appeal of modern free breathing power plants. But.... IMHO, old cars and trucks should have CARBURETORS. Something about seeing a fuel injection computerized system just don't set right with me. Share this post Link to post Share on other sites
8ntruck 6,997 #7300 Posted October 12 Just now, ebinmaine said: I do understand the appeal of modern free breathing power plants. But.... IMHO, old cars and trucks should have CARBURETORS. Something about seeing a fuel injection computerized system just don't set right with me. There are intake manifolds available for the LS that will mount a carb. I am considering a Quadrajet 'cause I like the 'Quadrajet howl' when you mat the gas pedal. 2 Share this post Link to post Share on other sites
