Ed Kennell 38,174 #6776 Posted May 11 These tail light brackets sticking out were a real knee knocker. So I cut them off and moved them to the rear where they are protected and can be seen much better. I use magnetic base lights on all my trailers. I keep them inside and take them off before dunking the boats in the salt water. They always work. Oh, and I did find you can use a 4.5" angle grinder for manicuring. If you remove the guard, try to remember to wear your gloves. 7 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,297 #6777 Posted May 11 @Ed Kennell You had a @Pullstart moment. 8 Share this post Link to post Share on other sites
Pullstart 62,877 #6778 Posted May 11 It happens.. 1 6 Share this post Link to post Share on other sites
8ntruck 7,004 #6779 Posted May 11 While we were in our winter quarters, the sump pump in our summer quarters decided to blow the circuit breaker that it is plugged into. I pulled the pump out of the crock today. It rotates freely, so it is an electrical issue. Don't have any idea how old the pump is - likely 20 to 30 years. I'll replace it. Fortunately, we didn't need a sump pump this spring, like we have in some past spring's. 4 Share this post Link to post Share on other sites
Horse Newbie 7,069 #6780 Posted May 11 7 hours ago, squonk said: Phil Bowling Memorial Trailer Looks like a wheel barrow in reverse… Share this post Link to post Share on other sites
Tractorhead 9,064 #6781 Posted May 12 (edited) 13 hours ago, Ed Kennell said: Oh, and I did find you can use a 4.5" angle grinder for manicuring. If you remove the guard, try to remember to wear your gloves. Nice manicureEd, maybe little rough for my opinion...😎 Her by our local OSHA it was strictly forbidden to wear gloves on any rotating Machines. But i don‘t care about. That prevents me several times to make an unwanted manicure. Try to start a battle with pullstart - huh 👍 Edited May 12 by Tractorhead 1 2 Share this post Link to post Share on other sites
Monstrosity 1,128 #6782 Posted May 12 So after the honey do osts were done I got 20 mins of play time before I need to start dinner! Recently picked up thus dual cylinder air compressor, cheapo one don't know how it'll work, so I'm thinking maybe to the front quick hitch with removable tank on back (larger tank) or mount the smaller tank underneath...... 3 Share this post Link to post Share on other sites
Tractorhead 9,064 #6783 Posted May 12 That compressor looks sharp in front of the Horse. 1 Share this post Link to post Share on other sites
Monstrosity 1,128 #6784 Posted May 12 8 minutes ago, Tractorhead said: That compressor looks sharp in front of the Horse. Now do I mount the smaller tank from or the big one on the back????? Share this post Link to post Share on other sites
ebinmaine 67,497 #6785 Posted May 12 25 minutes ago, Monstrosity said: Now do I mount the smaller tank from or the big one on the back????? Will the front mounted tank present ANY ground clearance issues whereever you use the tractor? On our rough terrain I'd HAVE to keep extra distance so I'd go with a high mount or rear tank. 36 minutes ago, Tractorhead said: That compressor looks sharp in front of the Horse. Agreed 👍 1 Share this post Link to post Share on other sites
Monstrosity 1,128 #6786 Posted May 12 34 minutes ago, ebinmaine said: Will the front mounted tank present ANY ground clearance issues whereever you use the tractor? On our rough terrain I'd HAVE to keep extra distance so I'd go with a high mount or rear tank. Ground clearance is an issue, and a rear attachment is an issue.... so the 1277 is Max's tractor and will be using it driving his siblings to the park... I may throw the mowing deck on so he can use it. He is currently learning with the push mower...his lines got me bothered..... I can fab up another pin hitch for the small yard cart on the back of the big tank so I believe that's the solution. My mower is a little larger on Saturdays. Go ahead shame me lol........ 1 1 Share this post Link to post Share on other sites
ebinmaine 67,497 #6787 Posted May 12 6 minutes ago, Monstrosity said: . I can fab up another pin hitch for the small yard cart on the back of the big tank so I believe that's the solution Big tank on a separate trailer? That'd work. Share this post Link to post Share on other sites
Handy Don 12,227 #6788 Posted May 13 47 minutes ago, Monstrosity said: My mower is a little larger on Saturdays. Sod farm? Share this post Link to post Share on other sites
Monstrosity 1,128 #6789 Posted May 13 18 minutes ago, Handy Don said: Sod farm? Yessir f&w schmitt my cousin has got me working year round now. 2 Share this post Link to post Share on other sites
Monstrosity 1,128 #6790 Posted May 13 (edited) 1 hour ago, ebinmaine said: Big tank on a separate trailer? That'd work. Eh I got plenty of wheels that'll work but I'm thinking something like this so I can use it as weight for plowing/snowthrowing. 2 pieces of steel with a pass through hole so can be mounted on the dozer blade frame with 2 holes to lock it up where the brinely/sleeve/pin hitch would mount to hold it in the up position. Edited May 13 by Monstrosity 1 1 Share this post Link to post Share on other sites
Horsin'round 79 #6791 Posted May 13 On 5/11/2024 at 6:08 PM, Ed Kennell said: These tail light brackets sticking out were a real knee knocker. So I cut them off and moved them to the rear where they are protected and can be seen much better. I use magnetic base lights on all my trailers. I keep them inside and take them off before dunking the boats in the salt water. They always work. Oh, and I did find you can use a 4.5" angle grinder for manicuring. If you remove the guard, try to remember to wear your gloves. Grandma always said, " You put a little bit of yourself into everything you do..."🤣🤣🤣 Glad you are alright, could have gone sideways quickly! 1 1 1 Share this post Link to post Share on other sites
Tractorhead 9,064 #6792 Posted May 13 (edited) 5 hours ago, Monstrosity said: Now do I mount the smaller tank from or the big one on the back????? Big one in the back to make it more useful imho. i would make it quick removable with a fast coupling. 3 base ideas behind: 1. quick removable if you need the space for other tasks 2. You can put a T connector inside if you need much more Air for whatever tasks, if needed you can attach an Trailer with an Airtank or other things ( free purpose decision) 3. In Winter you can use the Airtank instead with a separate Ballast tank i would never fill an Airtank with Water or Water Antifreeze or even oil, a open box what can be filled with sand would be my choice instead. Edited May 13 by Tractorhead Share this post Link to post Share on other sites
Mickwhitt 4,624 #6793 Posted May 13 What did I do? Hmm..... Mowed the lawn, watered the newly planted veg plants, continued my greenhouse building project, installed a new outdoor tap for said greenhouse, planted up hanging basket tomatoes and a couple of flower planters, made a home made pizza for lunch, laid a trial 1 metre square of stabilised gravel to see how it would look and perform..... just a few bits and bobs. Meanwhile, Sandra and her Ginnies girls hit the road and drove to the coast for a jolly day out. Oh then, when the sun had sunk into the West I had to water the community garden with my patented water pump system, home in time to greet the weary travellers. 4 2 Share this post Link to post Share on other sites
8ntruck 7,004 #6794 Posted May 14 (edited) Today was plumbing day. I installed the new sump pump in the house. Went scary easily. Swapped the fittings and pipe bits and bob's from the old pump to the new one, plugged it inand was done. Couldn't find a 1/3 hp pump, so the horsepower rule was applied and I settled on a 1/2 hp unit. Next up, the pressure tank in the lake house. 1st hardware store had sold their last 20 gallon tank yesterday. 2nd hardware store had one in stock. Old tank removed in about 10 minutes. Oops, old tank had a plastic elbow inlet fitting that extended to the outside of the tank base - new tank just had a standard elbow. No 1" galvanized pipe on my stash of plumbing odds & ends. Measured old tank & new tank to come up with a length. Back to the hardware store for a piece of pipe. Assembled onto the new tank. Place tank into position - oops #2. The pipe was about 3" too long. Turns out the new tank is larger diameter than the old one - moved the tank centerline. Back to the hardware store for the 3rd time. Pick up the new calculated length pipe and a spare that is an inch shorter. Swap the new length pipe into place, place the tank. Measured correctly this time - lines up with the union to the rest of the plumbing system. Started the pump up - no leaks. Got lucky on the sump pump - one trip to the store. Pressure tank turned out to be the average three trip to the store project. Also added a too long pipe and a too short pipe to my stash of plumbing parts that don't fit anything in the house for possible future use. Edited May 14 by 8ntruck 2 3 Share this post Link to post Share on other sites
ebinmaine 67,497 #6795 Posted May 14 18 minutes ago, 8ntruck said: Went scary easily And here, ladies and gentlemen, we should know by now to STOP all further projects for the next 24 to 48 hours. 2 1 Share this post Link to post Share on other sites
87 416-8 horse 420 #6796 Posted May 15 3 hours ago, ebinmaine said: And here, ladies and gentlemen, we should know by now to STOP all further projects for the next 24 to 48 hours. True true. Those are some wise words @ebinmaine 1 Share this post Link to post Share on other sites
ClassicTractorProfessor 5,314 #6797 Posted May 15 Started working on repairing the non working Touch Control hydraulics on the Cub LoBoy this evening after work 3 2 Share this post Link to post Share on other sites
OldWorkHorse 3,045 #6798 Posted May 15 Worked a bit more on the mythical beast today. Still got a few parts to put on once i get them but not bad for mostly scrap pile i got for free. 4 2 3 Share this post Link to post Share on other sites
SylvanLakeWH 25,557 #6799 Posted May 15 That is cool!!! 1 1 Share this post Link to post Share on other sites
Pullstart 62,877 #6800 Posted May 16 Win some, lose some. $40 for the seat, but $50 for the plow! 8 1 Share this post Link to post Share on other sites
