WHX?? 50,570 #5651 Posted May 14, 2023 On 5/13/2023 at 11:20 PM, JCM said: Wish I was 35 again. As gorgeous George said Plunge... get a haircut and get a real job! Well oh nevermind I forget you are a journeymen. You need to pull the pin Jim... better times to be spent up at the love shack... ❤️ just sayin... 2 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5652 Posted May 14, 2023 (edited) So the yellow and white tractor(my grass cutter), was needing her deck blades sharpened, oil and filter change, chassis lube, and the air / pre-cleaner filter serviced. When I backed her out of the stables, proof was left on the floor… Slid the deck out from under her belly, but before I got into the blade sharpening and spindle lubing, I decided to service the tractor first. So in my usual fashion, I went a little past an oil change… I figured now would be a good time to remove some of the grime … I wound up with the air filter back plate off because I couldn’t get to some of the grime. I wound up making a gasket that goes between the backing plate and the carb. Since I was this far along I dropped the carb bowl and emptied that out. I used Lucas Red Tacky grease to grease the wheel bearings, front axle pivot shaft, steering knuckles, and all other grease fittings… Got the grease gun hung up on the grease fitting on the steering gear box and didn’t think I was gonna get it loose… Didn’t finish the tractor service much less the deck… Edited May 14, 2023 by Horse Newbie 7 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5653 Posted May 14, 2023 Got part of removing grass build up from the underside of the deck today… would have finished it if I had not broken the first paint removal disc on my right angle dye grinder… I was using a rubber backing pad and I should have been using a plastic one. Naturally this sharpen blades, clean underneath, and grease the spindles turned into the underside getting prepped for the POR-15 treatment… 6 Share this post Link to post Share on other sites
formariz 11,993 #5654 Posted May 16, 2023 Did some reflecting while watching the reflection on the pond. 4 1 Share this post Link to post Share on other sites
8ntruck 7,344 #5655 Posted May 16, 2023 (edited) More cart work for Morgan, the 14-8. Hauled a couple loads of leaves left at the shoreline up into the woods. Next, I hauled 4 dock sections from winter storage stacks to the yard behind the lake house for washing and another coat of stain before going into the lake. The dock job got unexpectedly moved up the list today. I called the boat dealer where our pontoon is in winter storage to see if they could get it ready to pick up before Memorial Day. No problem, they said. Will call you when it is ready. Got a call from them a few hours later, saying the pontoon is ready to pick up. Seems the tech just happened to have our pontoon hooked up to the fork truck moving it out of the way to get a different boat out of storage when the request for my pontoon hit the shop. Since mine was hooked up to the fork truck, it got rolled into the shop and de-winterized first. Edited May 16, 2023 by 8ntruck 2 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5656 Posted May 17, 2023 I thought “flying fish” at first… Share this post Link to post Share on other sites
Horse Newbie 7,194 #5657 Posted May 17, 2023 Took the angle grinder and some sanding discs to the Cub deck some more… Prepping for the POR-15… Yellow paint, and red oxide primer going, going, almost gone… 1 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5658 Posted May 20, 2023 Finished cleaning the underside of the Cub deck, prepped for the POR-15… I achieved the white powdery look on the metal, so I went for it. Now to go see what my neighbor Grady is doing… 4 3 Share this post Link to post Share on other sites
ebinmaine 70,404 #5659 Posted May 20, 2023 On 5/20/2023 at 8:04 PM, Horse Newbie said: Finished cleaning the underside of the Cub deck, prepped for the POR-15… I achieved the white powdery look on the metal, so I went for it Excellent transformation 😁 1 Share this post Link to post Share on other sites
19richie66 17,560 #5660 Posted May 20, 2023 (edited) Picked up a 416-8 carcass. I just wanted the engine but he wanted the whole thing gone. Who am I to argue? Edited May 20, 2023 by 19richie66 5 4 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5661 Posted May 21, 2023 I got yelled at for tying a tractor down with clothesline… 2 4 Share this post Link to post Share on other sites
ebinmaine 70,404 #5662 Posted May 21, 2023 On 5/21/2023 at 4:07 AM, Horse Newbie said: I got yelled at for tying a tractor down with clothesline… You're Right! @19richie66 You've been BAD !!! No rope. No bungies. Ooooooooooooooo..... 3 Share this post Link to post Share on other sites
19richie66 17,560 #5663 Posted May 21, 2023 On 5/21/2023 at 8:32 AM, ebinmaine said: You're Right! @19richie66 You've been BAD !!! No rope. No bungies. Ooooooooooooooo..... All my tie downs are at home. Luckily it fits in the bed. I have it sitting on 2x6 boards now so it won’t rock. Should make it home 😁 2 Share this post Link to post Share on other sites
c-series don 9,381 #5664 Posted May 21, 2023 @19richie66 That must have been a hard one to push in the truck 🤣😂 I’ll bet you were mad when you had to take the free transmission that came with the deal !! 2 1 Share this post Link to post Share on other sites
19richie66 17,560 #5665 Posted May 21, 2023 On 5/21/2023 at 11:22 AM, c-series don said: @19richie66 That must have been a hard one to push in the truck 🤣😂 I’ll bet you were mad when you had to take the free transmission that came with the deal !! Very upset 😂 He loaded it with a fork attachment on his kubota. Neither of us even broke a sweat. If had known I was getting it, I would have made sure I had something to secure it better before I left home. Should be fine 2 1 Share this post Link to post Share on other sites
Rick3478 433 #5666 Posted May 21, 2023 On 5/20/2023 at 9:05 PM, 19richie66 said: Picked up a 416-8 carcass. I just wanted the engine but he wanted the whole thing gone. Who am I to argue? Good find! Who takes off the wheels and leaves the good stuff? Just sayin'. So if you just wanted the engine ... no, bad thought, too far for me to drive. 1 Share this post Link to post Share on other sites
Oldskool 6,660 #5667 Posted May 21, 2023 Did, doing, still doing. Feeding the hungry ole rolling brush burner. Taking advantage of the rain from last night/morning. 5 1 Share this post Link to post Share on other sites
ebinmaine 70,404 #5668 Posted May 21, 2023 Since we had a hard freeze the other night Trina and her mom lost a bunch of plants. They each went to different places to purchase replacements. All local. Today they're out transplanting. 74 total. Many tomatoes. Zucchini. Other green stuff. 😁. The three of us are also spending some time cleaning up and reorganizing the yard, barn, and tractor parts/future project tractors pile. 2 Share this post Link to post Share on other sites
Ed Kennell 40,316 #5669 Posted May 21, 2023 On 5/21/2023 at 5:01 PM, ebinmaine said: we had a hard freeze the other night Trina and her mom lost a bunch of plants. Sorry to hear this. I'm fearful every spring that a late frost will kill my fruit tree buds. I got lucky this year...looks like a good crop of apples, pears, and plums. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,404 #5670 Posted May 21, 2023 On 5/21/2023 at 5:12 PM, Ed Kennell said: Sorry to hear this. I'm fearful every spring that a late frost will kill my fruit tree buds. I got lucky this year...looks like a good crop of apples, pears, and plums. Thanks Ed but no worries. Trina's ALWAYS got a good back up plan. We've been mulling over building a tighter greenhouse that can be heated... Or keeping all the plants on more mobile platforms for easier transport in/out of the heated basement. 2 Share this post Link to post Share on other sites
Oldskool 6,660 #5671 Posted May 21, 2023 On 5/21/2023 at 5:17 PM, ebinmaine said: Or keeping all the plants on more mobile platforms for easier transport in/out of the heated basement. Our little green house is built that way. 4ft x 8ft wheels and casters. 1in water pipe hoops for the supports. Clear plastic top. The top is on hinges to easily tend the plants. We can roll it around the yard for better sun. If it looks like frost is coming just roll it into the garage. If it had a hitch that would make it so much better 2 Share this post Link to post Share on other sites
19richie66 17,560 #5672 Posted May 21, 2023 On 5/21/2023 at 1:30 PM, Rick3478 said: Good find! Who takes off the wheels and leaves the good stuff? Just sayin'. So if you just wanted the engine ... no, bad thought, too far for me to drive. I originally only wanted the engine but had no problem taking the rest with me. 2 Share this post Link to post Share on other sites
Wheel-N-It 2,971 #5673 Posted May 22, 2023 On 5/20/2023 at 9:05 PM, 19richie66 said: Picked up a 416-8 carcass. I just wanted the engine but he wanted the whole thing gone. Who am I to argue? Good score Richie!!! The 416-8 is one of my top favorite Wheel Horses. They will do anything yo ask of them. When you get it running, throw that pepper shaker muffler away and put a stack on it. 1 Share this post Link to post Share on other sites
WHX?? 50,570 #5674 Posted May 22, 2023 Parts is parts @19richie66... 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,194 #5675 Posted May 22, 2023 Finished up Grady’s wife’s She-Shed by figuring out the little wiring problem, putting a drain line in from a downspout coming from his shop next door that will run under the she shed concrete porch, finishing all the caulking around the outside of the shed, putting up the ceiling fan, last receptacle… Now I can concentrate more on my projects, like the C-160… 7 1 Share this post Link to post Share on other sites
