RandyLittrell
K301 rubber compression bushings.
RandyLittrell
You guys have a source for the rubber compression bushings that goes on the metal fuel line from pump to carb on my 1277? I know I have bought them in the past locally, but everyone in town just gives me a blank stare when I ask! Even the old guys at the parts counter, computer's have dumbed our country down!!
Randy
wallfish
Hardware dept of any good store will have the brass fittings. It's not a rubber compression piece, typically brass.
Just buy a whole new fitting, they're not expensive
SPINJIM
I just replaced mine with the newer black fuel line.  Figured the larger diameter had less chance of clogging, and would have better flow.  Only had to buy two new 90 degree elbows to replace the compression style elbows.  Not authentic original, but I think is's an improvement, and it's hidden under the hood anyway.
  Jim
Edited by SPINJIM
953 nut
I bought some from Zoro a couple years back.
3/16" COMPRESSION VITON SLEEVE 10PK
PARKER| Zoro #: G2130703| Mfr #: 60VLV-3
0.0
No ReviewsWrite the First Review
Pipe and Fittings Size Guide
DETAILS:
Item: SleeVe
Temp. Range: -15 Degrees to 450 Degrees F
Tube Size: 3/16"
View Full Product Details
Orders over $50.00 ship FREE. DetailsStandard ground shipping
Limited Stock
Item ships from Zoro in 1 business day.
$7.36/PK
RandyLittrell
Yes, they have lots of those, just hate switching out the hole thing, when all I need is 20 cents worth of rubber bushings. The carbs from the sixties had a steel fuel line with little rubber compression bushings, worked for over fifty years!! My old ones are not super bad, may try and reuse them. Just wanted to be done with it!
Not sure a fat o-ring wouldn't work though, might try that.
Randy
Edited by RandyLittrell
RandyLittrell
0.0
DETAILS:
Item: SleeVe
Tube Size: 3/16"
Limited Stock
$7.36/PK
Thanks for the heads up!!
Randy
squonk
You can buy the little 3/16 brass ferrule at any hardware store and it will look original.
Achto
If you have a Harley Davidson shop near by and the parts guy remembers what a Shovel head is. Those same bushings were used for Shovel Head rocker box oil lines. These are what I use. My local after market Harley shop keeps them in stock.
  • Like 5
  • Excellent 2
WHX??
:text-yeahthat:I ordered a bunch cheap off fleabay.
In a pinch I once used some evap/vacuum/windshield washer tubing I had laying around. Worked pretty good. I use a little backing washer between the nut and the rubber.
RandyLittrell
I can throw a rock and hit the backside of Mike's 71 cycle shop from my house, (if I was younger!) it will be my first stop tomorrow!! He is as old school as it gets.
Randy
WHX??
He'll have them then Randy ... works fine lasts along time... :handgestures-thumbupright:
RandyLittrell
About 53 years the first time!
Randy
RandyLittrell
Here they are. I posted in my other thread about punches, but thought I would post a pic here for others searching at a later date.
The guy at Mike's cycle shop, just went in the back and got them! No messing around there!
Randy
RandyLittrell
Here she is, back together with no leaks! I have to say, I think she may run better than it has since I bought it. Hopefully the china carb will hold up but I will go ahead and rebuild the original carb for a spare if I have issues. I put it right to use cleaning out the road bank that the PO had placed rocks, bricks, and chunks of concrete trying to landscape. Didn't work, it looked like crap! Now to get some grass or ground cover growing.
Thats all the rocks and concrete chunks at the other end.
Randy
