River19 87 #1 Posted April 27, 2020 For as long as I can remember, our particular C-160 Hydro had an issue where the e-brake seems to not fully "lock" or stay in the down (disengaged) position when underway. So it feels like it springs up about an inch and causes drag and in order for it to not scrub forward speed I have to hold it down. Anyone encounter this issue? I am making the assumption this might be a regular known issue with a common fix so I figured I would ask as I am now doing my research on what might be needed to remedy. Thoughts? Thanks Steve 1 Share this post Link to post Share on other sites
Achto 27,285 #2 Posted April 27, 2020 (edited) I'm going to guess that you have a Sundstrand transmission in your C-160? If so the parking brake should look some thing like this. Here a few things to look at. I would check all of the pivot points and lube them with a little oil. A weak spring (which would be my best guess) may be the issue. Too short of a drive belt may cause the mechanism to not be able to break center properly. Edited April 27, 2020 by Achto 1 1 Share this post Link to post Share on other sites
River19 87 #3 Posted April 27, 2020 1 minute ago, Achto said: I'm going to guess that you have a Sundstrand transmission in your C-160? If so the parking brake should look some thing like this. Here a few things to look at. I would check all of the pivot points and lube them with a little oil. A weak spring (which would be my best guess) may be the issue. Too short of a drive belt may cause the mechanism to not be able to break center properly. Thanks, and holy hell that is a nice clean looking rig...... I'll pull the cover and see what I can find....we'll start with the simple things. 1 1 Share this post Link to post Share on other sites
Achto 27,285 #4 Posted April 27, 2020 Just now, River19 said: Thanks, and holy hell that is a nice clean looking rig...... Thanks, Just happen to have this assembly picture from my latest resto. 1 1 Share this post Link to post Share on other sites
pfrederi 17,518 #5 Posted April 27, 2020 Check the bottom of the circled pin. They can get a groove worn in them (other pic) which can affect engagement. 4 Share this post Link to post Share on other sites
