3WHDave
Oil Temp Gauge
3WHDave
This is a new response to an old post...
I’m restoring a D180 and like many, my oil temp gauge has a broken needle.  The plastic was not UV stable and deteriorated to the point of near-powder.  I see many posts on oil pressure, but not on temp gauges.  I did disassemble the old gauge and it appears to be fine (removing bezel is a pain, slow going expanding crimp).  Is there an OEM, or near OEM source?  Again, all suggestions are appreciated.  PS: engine reasonably going well, may fire it up with temp gas tank, mine is out for paint sand blasting. Last resort: 3D print a needle.
WHX??
Check with A-Z tractors https://a-ztractor.com/ he may have a good used one.
3WHDave
Thank you WHX24, I will do so!
